Bugeye dual horns
rossco
'59 Bugeye. Dual horn set-up. No relay, Moss says I don't need it. I've wired the two horns in series. (pigtails across the terminals) I now have two.wires off one horn that are looking for connections. My loom has a brown/green tracer and brown and black tracer. Do I connect my horn wires to these tracers and how do they match up? Brown and green goes to the fuse block, brown and black to the horn button which I don't have yet. This is all guess work. Please check my work.
Bill Young
assuming the horns are rated 12 vdc ... wire them in parallel
R
rossco
I think I've done that at the horns. It's affixing the horn wires ( which I assume are now parallel) to which tracer wire ends that I'm totally baffled. P.S. The horns appear to be fitted as original equipment.
Bayless
If you have 2 wires from one horn then I think you have them parallel. If you have wires between the horns then there should be 2 wires between them. The diagram shows 2 separate wires from the relay, one to each horn then both grounded. The NG wire is the hot wire to the relay and the the NB wire is the relay coil and goes to the horn button. There should be a NY wire from the relay to each of the horns and a B wire from the horns to ground. If you are not using a relay then the NG wire would got directly to the horn or connect to the NY wire. As you adjust to the Lucas way of doing things, the color codes are as follows.
N = brown
B = black
Y = yellow
R = red
G = green
W = white
U = blue
P = purple
K = pink
Wires with a tracer color have gone through a switch (mostly) other than the ignition switch. Solid color wires have not, again except possibly the main ignition switch. You really need that diagram.
R
rossco
I have two diagrams. I've never used one and I'm trying to find my way along. Hooked both wires from the horns to test battery, got sound. Reversed the wires and got sound. Checked for continuity on NB horn push wire - o.k. Checked for continuity on NB wire to fuse B - o.k. Now can I join the two wires from the horns to the two loom wires and hook up a manual horn button because a don't have a horn button on the steering wheel.
Bill Young
will this logic diagram help? Shows a single horn, however, same with 2 horns in parallel ..
  • Bugeye E1.pdf
RickF
Here is a schematic that shows how the factory wired a single horn or the optional dual horn setup.
#19 is the fuse block. #23 on the bottom of the drawing is a single horn and #24 is the horn button. At the top of the drawing the two #23's are the dual horns, #42 is the horn relay, and #24 is the horn button.
Bayless
I think I made a misleading or at lease incomplete statement above about wiring around the relay. The NG wire from the fuse box goes to one of the horn wires. The other horn wire goes to your horn switch. With a standard horn button this wire is NB somewhere in the wiring harness. Since you are adding a separate button, you probably will have to supply a separate wire from the horn to the button. The other side of that button then must be grounded.
JPSmit
you may want to install a relay. (I have one on each horn and also on the headlights.) It is an inexpensive and easy way to lower current draw on already fragile wires.
JPSmit
What relay do you use and do you just install it in line? I've never done a relay.
Relays are fairly logical and not hard to wire. All relays have standard markings as per the diagram, you would run the existing horn wires from the battery to 86 to 87 to the horn (which grounds when you push it)
this creates a small electromagnet which is wired: new line from battery (mine comes from the solenoid) to 30 - and then from 87 to the horns which are grounded as per the diagram. any relay you buy from anywhere will be marked 85/86 - and 30/87. Some even come with harnesses.
Ignore 87a in the diagram this is an extra terminal for something like a high/low headlight beam.
good luck!
JPSmit
JP. Thank you! I'll look at this fresh in the A.M. when I have a fresh head. I'm up too late for an oldguy.R
I get that!
BTW I have two relays and two wires - one on each horn
JPSmit
Where are they mounted?
I have a square body Midget. IIRC the horn ones are behind the grill on the horn brackets and then I have three more on the drivers side mounted on the inner fender near the front - They are out of sight and are for low beams high beams and a spot light.
apbos Interesting dual cylinder Bugeye setup Spridgets 6
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
