Wiper switch repair
sparkydave
My wipers have been out of commission for a while since the wiper switch gave up the ghost. Has anyone tried to repair one? Moss has replacements, but they have been backordered for months and Moss has no idea when it will come. I figured I could either attempt to repair it, or wire a toggle switch under the dash into the old switch harness, that way the wipers can be functional again until (if?) the new one arrives. So far just trying to avoid driving it if rain is in the forecast, but I'd rather be street legal.
Much obliged, looks like the MGB switch is very similar, so I should be able to apply that to the Midget. Many thanks!
Perhaps the switch's contacts are a little corroded. Consider removing the switch and squirting a little - or a lot - of WD 40 into it. then work the switch on/off several times. Install and check. The switch might decide to start behaving after this treatment.
Follow up, I finally dug into it. Turns out the steering column can be flexed down enough to get the shell off without having to remove the whole thing. A couple of the fixed contacts were corroded, and the moving contact was fitting very loosely on the arm. Some polishing up with some contact cleaner and Q-tips, some careful bending of the contact arm, and the wipers are working again. Dabbed some lithium grease on the ball detents and it operates much more smoothly. Coincidentally, two days after fixing it, Moss e-mailed me that the repro switch I ordered a few months ago has gone from backordered to discontinued.
Shealey How to repair a wiper switch with photos Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
KVH TR4/4A Wiring to TR4A Wiper Switch Triumph 14
6TTR3A TR2/3/3A 2-speed wiper switch? Triumph 7
H TR4/4A Wiper 2-speed switch wiring 4a Triumph 12
wingsandwheels TR6 Late TR6 Wiper/Wash Switch Triumph 0
W TR6 wiper park switch-tr6 Triumph 2
G 6 wiper switch mount. Triumph 7
W TR6 wiper park switch-tr6 Triumph 7
W wiper switch? Triumph 2
Bob Claffie Wiper switch Triumph 2
S Spitfire Replacement Wiper/Washer Switch for '70 Spitfire Triumph 0
Brinkerhoff TR6 TR6 wiper switch '74 Triumph 1
E BE Wiper Switch Knob Spridgets 8
jvandyke fog light/wiper switch? Spridgets 1
mountainman TR2/3/3A TR3 Wiper Switch Triumph 5
R TR6 TR6 Wiper Switch Fitment Question... Triumph 3
apbos Wiper switch knob removal Spridgets 2
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
M Spitfire windscreen wiper switch for '69 Spit Triumph 7
J Spitfire Wiper Switch 78 Spitfire and Wiper function Triumph 3
Got_All_4 TR5/TR250 TR250 WIPER SWITCH PROBLEMS/ QUESTION Triumph 3
Webb Sledge Wiper Switch Triumph 8
R Wanted - Series2 XJ6 wiper switch Jaguar 1
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
