TR6 wiper park switch-tr6
Wike
Anybody have a clue as to the installation of a wiper motor park switch? I am guessing it mounts to the wiper motor itself due to the small plunger type pin on the new park switch. When I connect the wires to the switch the wipers run...when I manually push the plunger in on the switch, the wipers shut off.
TR3driver
Great Pumpkin - R.I.P
That's the way I remember it; just two small screws that hold the switch to the side of the gearbox. The little plunger sticks through a hole and rides on the big gear.
But it's been awhile since I was inside a TR6 wiper motor, so the exact details are fuzzy.
W
Wike
After looking at several views found in the Rimmerbros website under wiper motors, it was sort of clear that the park switch I was trying to figure out was located on the underside of the wiper motor...the plunger goes in to the motor gear via a small hole while the other end, which has a plastic peg, fits into a small hole. The trick is getting the small clip attached to the park switch which holds the switch to the motor to engage in the slot on the wiper motor while getting the prior to line up. I found by prying the clip open just a bit worked. Thanks all for the help
W TR6 wiper park switch-tr6 Triumph 7
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
Gordon_Dedrick TR 3 wiper motor park Triumph 1
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
JFS TR2/3/3A Wiper Cable Lube Triumph 5
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
sparkydave Wiper switch repair Spridgets 5
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
