Wheels or Rims Lug Pattern
algot1901
Bronze
My Prefect has the typical European rims that are 6.00 x 16" and the wide five-lug pattern, I would like to bring it down to a 15" or 14" with the 4 1/2" bolt pattern. I think the older bugs used this wide-five, I see I can buy wheels that use the wide-five pattern but are 15".
What's your question? Are you looking for information on what will fit?
I have a chart that I've kept from an old Auto World catalog that I refer to.
I found an adaptor that will go from 5" to Ford 4 1/2", also found rims that have the 5" lug pattern that are 15" and will take our modern tires, I really want to get rid of the factory wheels which are 5.00-16. I believe the VW factory rims of that era are the same as the Prefect
VW wheels are 15 inch. I have TR3 wheels on mine with adapters. they are same width as VW and take the same tires. I have same tires on Prefect and VW, either I think 155R15, probably 85 sidewalls, whatever was right for the VW. That makes the speedo almost correct so diameter is acceptable although they are an inch or more wider that the original 500x16s. I guess I failed to mention that I have the complete hydraulic brakes, including drums, from a '58 Prefect. The adapters are from those drums to the TR3 wheels.
Looks like lots of choices here
Curious what year Prefect do you have, I have found rims as low as $60.00US 5-205 4.5 tire width I am going to stay with push and pray binders and I also have learned that the exchange rate will put you in the poor house. I wonder if the VW brakes would work though.
Thank you
It's a '48 Prefect and it wears Triumph TR3 wheels with VW tires. Brakes are '58 Prefect throughout.
Did you have any problem with the offset?
What size are the skins?
When I did the brake conversion I originally went with the '58 wheels and 13 inch tires. That gave an unacceptable top speed of about 42 mph. The TR3 wheels were given to me so I didn't worry much about the offset, still don't know. My adapters are about 3/8 inch thick and the 165R15 (I'm pretty sure) tires fit quite well. The rolling diameter is very close to the 500x16s so the top speed is acceptable again although I have not tested it since. I can at least drive with traffic without feeling like the little flathead is flat out.
Monday I am going to order the rims/wheels and tires 165R15 is about 6 1/2" now I have to decide black or white sidewall. Today I was cleaning the engine parts of that 50+year tar and being a boomer I just find it hard to wear plastic gloves, lots of Lava soap, and a knuckle brush also wash dishes tonight the old way. Seems like it took forever to get the crud of the sparker so I could get the serial number, I am going to go with Pertronix beats the hoot-out points.
Seems like you are learning a lot from this car. Which wheels and tires did you eventually purchase?
I purchased the wheels from BJBUG just a plain rim 15x5". Today is valve lap day and if I have enough time I am going to sandblast the Roof twhere the top gasket goes is lock.
tinman58 TR5/TR250 250 wheels [rims] Triumph 23
G Modified Rims [Wheels] - Good Idea? Sunbeam (Rootes) 9
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W For Sale Wheels for sale Austin Healey Classifieds 1
glemon Wanted TR250 Wheels Triumph Classifieds 1
D MGB BWA Alloy Wheels MG 9
T TR2/3/3A minilite wheels Triumph 5
R Bugeye splined wheels Spridgets 0
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
P TR5/TR250 Wire wheels width Triumph 8
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Wire Wheels and Air Leak Austin Healey 16
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
Y MGB Aftermarket wheels MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
R MGA wheels MG 10
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
F TR6 Wheels and tires Triumph 10
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M TR6 Center cap for wheels Triumph 2
C Replacement wheels Rover / Land Rover 1
B Refinishing Minilite Magnesium wheels Restoration & Tools 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Recommendation on wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
DerekJ Original steering wheels Austin Healey 1
B TR2/3/3A Tubes in steel wheels? Triumph 18
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
