Wheel Bearing Grease/ Impact wrench on hubs
Jim_Gruber
Gotta makea trip to O'Reoilly's in the AM for 2 new cotter pins and wheel bearing grease so Bugsy can finally no longer be a member of the wobbly wheel club. Any recommendations on grease type?
Another question, since I pulled the caliper already and issue with using the impact wrench on the wheel hub, set at less than 600 foot lbs of torque of course. I'll have sprayed with PB Blaster overnight and I had these apart 5-6 years ago so it's not like it's been 40 years. The last thing I want to do is break a bolt off. It's supposed to be 55 or so tomorrow and if the wobbly wheels get fixed Bugsy is going for a ride.
Jim, the wheel hub nut should not be that tight. Try a wrench first, I bet it comes right off. I have never had one of these nuts give me any trouble.
I like Castrol wheel bearing grease. It just goes with all the other lubes on a Brit car. I use all Castrol products.
Cotter keys. Buy the plastic boz with a bunch of all sizes, you will never need to get any in the future. Make em stainless from the boat supply house.
Wheel Hub Nut I'm sure will come right off. I was talking about the 4 bolts holding the rotors on. After thinking about it I realized, No I do not need to take those apart to simply change the wheel bearings.
Frank and Jack, thanks for the info.
No you don't and only two bolts from the back hold the rotors on. Leave those two on the front alone.
Jack,
On a '68 4 bolts hold the hub to the rotor. While the hub was still on the spindle, I used impact wrench on low torque setting to undo the four bolts. You can read my other #$#!$### post regarding replacing a wheel stud which necessitated taking the hub apart. I just don't know my own strength.
Hopeing to pull the front hubs today on the 67 so will count bolts. I do know the 72 only has two bolts and a Miata only has one.
Jack I pulled mine apart yesterday to replace the wheel stud. I found just one in the bottom of my junk nuts and bolts box. There are 4 9/16" bolts on that hub holding on the rotor. I used my impact wrench on a low setting and had to use a regular 9/16" socket, not one of the heavier black impact sockets to get in there. Clearances are real tight in there. Zipped right off after being PB Blasted overnight.
OK Guys, I am a newbe and was wondering what is PB Blast? I have a 71 Midget in restoration no mans land and a few bolts that are giving me grief. HELP!
Welcome! PB Blaster is a great penetrating oil, and will get almost any stuck nut or bolt free. Douse liberally, and wait a few hours. It may need more than one treatment, but that's rare. Most part stores carry it.
Hope to hear more about your '71 restoration! :savewave:
In addition to PB Blaster I also use heat, then, while it's hot - touch the threads with a candle - wax will wick into the threads - and then hit it woth Cold water to jolt it - pretty good success with all
Thank you both for getting my question answered so quickly. I will get some PB Blaster tomorrow.
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
TulsaFred Front wheel bearing grease packing Spridgets 26
S Wheel Bearing Grease/Repacking Austin Healey 1
PatGalvin Wheel bearing grease seal blues - they continue Triumph 15
drooartz Wheel bearing grease, what should I know? Spridgets 4
M Rear wheel bearing packed with grease? Austin Healey 5
T Front wheel bearing grease cup removal Austin Healey 1
C Spitfire rear wheel bearing Triumph 2
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Lin Cause of burned wheel bearing? Austin Healey 5
A Front wheel bearing issues Austin Healey 11
M Wheel bearing question Austin Healey 9
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
Bayless Need wheel bearing advice please Spridgets 4
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
C Rear wheel bearing or other cause? Austin Healey 18
T TR2/3/3A Another wheel bearing thread Triumph 5
G TR4/4A Front Wheel Bearing Seal Triumph 19
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
B Wheel Bearing Race Installation Austin Healey 7
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
steveg Spun wheel bearing traced to gasket thickness Austin Healey 16
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
S Problem removing front wheel bearing retaining nut Austin Healey 9
N Spitfire Front wheel bearing seal??? Triumph 11
Morris Another wheel bearing question Spridgets 3
Morris Wheel Bearing Shims Spridgets 2
7 General TR Chirping front wheel bearing Triumph 6
B Rear Wheel Bearing Oil Seal Spridgets 7
Morris Front wheel bearing installation Spridgets 4
H excessive wheel bearing shims? Austin Healey 11
NutmegCT TR2/3/3A TR3A wheel bearing? Triumph 7
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
G XKE rear wheel bearing replacment Jaguar 4
M Rear wheel bearing Spridgets 4
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
D MK2 front wheel bearing adjustment Jaguar 8
T TR6 TR6 front wheel bearing ? Triumph 5
tomshobby specific front wheel bearing questions Spridgets 8
N Spitfire Spitfire Timken wheel bearing numbers Triumph 5
ekamm Need Timken wheel bearing #'s Triumph 13
tomshobby front wheel bearing question. Spridgets 9
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
bigjones Wheel bearing replacement question Spridgets 60
bigjones Wheel bearing nut torque Spridgets 11
