    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Wedge TR8 rear wheel bearing noise / replacement
GBRandy
I have a noise coming out the back that sounds like a worn bearing. It is worse if the car is rolling without power, but goes away when power is applied.
The rear end I have is stock to the FI TR8 and has never been opened or touched in the 23 years I owned the car short of changing the gear lube( I have been using 90 weight oil).
While I intend to check all the bushings I recently replaced and ensure the shock are nice and tight, I suspect my issue resides in the axles or rear-end. Do I just start swapping bearings.....or is the preferred sequence to trouble shoot this?
BTW the car runs perfectly fine....just some noises.....
I am glad you asked, I have had three different axles and they all did this. I just assumed they all did this. MY issue now is I have a vibration when I do a gradual left turn (like in a bend in a road, not making a turn) I wonder if it could be a rear bearing related issue
I think that a wheel bearing would make noise whether power was applied or not. My 4 speed rear end makes noise when coasting and I think that the pinion bearing either needs r/r or the previous owner didn't set the gear mesh properly when he replaced the pinion seal.
I paid a shop about $800 to rebuild my spare 5 speed rear end including all new bearings, brakes, etc. I have a specially made wrench if for the nut on the pinion shaft if you need to borrow it.
PATR8,
That vibration sounds like it may be a spider gear bearing/bushing, or just worn spider gears.
why would it only be in gradual left turns, I do not under stand axles. I thought it might be bearings in the front so I swapped them out and it did not help. how hard is it to replace them?
PATR8,
I don't know. ISTM that spider gears rotate in different directions on right and left turns, depending on which wheel is travling faster and which is being driven. I think the slower (inside) wheel is being driven w/o locker. Someone correct me if I'm wrong, please.
May not be rear end?
Tires, broken belt?
Alignment?
I don't know.
If I have a revelation, I'll let you know.
Jim
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
T Wedge TR8 scraping noise from the passenger side rear Triumph 10
SCguy Wedge TR8 rear brake drum removal Triumph 28
SCguy Wedge TR8 rear end noise? Triumph 4
GBRandy Wedge TR8 Rear Brake Squeal Triumph 10
JFS Wedge TR8 Front & Rear Seals Triumph 4
D Wedge TR8 rear end Triumph 1
B Wedge TR8 Rear Brake help needed - please! Triumph 8
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
