What do you think - put a team together for this?
If you need a car to run in it this one was for sale. It was at the Brits by the Sea show in June.
D XK150 Transmission Input Shaft Jaguar 1
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
TR3MT TR2/3/3A Generator Output Triumph 18
T Got the engine put together Spridgets 4
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S TR6 After I put in my new oil pump.... Triumph 3
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
stretchit2 Motor Kaput Austin Healey 31
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
J TR4/4A Removal of spigot needle bearing from input shaft Triumph 1
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
K TR4/4A Gearbox input shaft pilot bush.... Triumph 4
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
bigjones Is this SU kaput? Spridgets 12
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
CJD TR4/4A TR3/4 Gearbox Input Shaft Triumph 8
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
J How to put a stop on the end of a choke cable? Restoration & Tools 2
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
S Idle Speed Setting versus Generator Output Spridgets 3
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
Nelson Speedo kaput Spridgets 6
S Your input on Kumho kr21 155/80r 13 tires Spridgets 21
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
J Clutch Problem - Seeking Input Austin Healey 4
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bill_powell MGB-GT Considering a B/GT; Input Please? MG 19
