TVR 2500M Triple Weber 40 DCOEs
True, but then the fuel wouldn’t come out of the velocity stacks.
Anyway - had the car out for a run around the neighborhood…. stayed at low RPM.
I have an airflow “synchrometer”, getting the following at 900 RPM Idle speed.
1: 2.5 kg/h
2: 3.0 kg/h
3: 8.0 kg/h
4: 8.0 kg/h
5: 3.0 kg/h
6: 2.5 kg/h
My reading seems to indicate the two center carburetors are too high, normal range is 1.0 - 2.5 kg/h.
I think this means the throttle plates are open a bit?
Advice on where to start my adjustment?
The Redline guidelines say (step 1) say: “all air bypass screws should be set in the closed position”…. On my carbs, I believe there are hard white plastic caps covering them, and they are non-adjustable?
Thanks -
Rocky
My guess would be that the throttle shaft on the middle carb is out of sync with the end two rather than bypass screws being mis-adjusted.
Again, a guess.
And I too think that throttle sync is a good guess as the first thing to check. I couldn't remember how you had the linkage set up so I took a look at it this morning (it was too late last night when I saw your post for me to trust my judgement) in one of your pictures. I would go to that turnbuckle link on the middle carb and adjust it. I can't help but feel it is holding the throttle plates open just a bit more than the other two.
As for the air bypass screws, they are indeed the ones under those little plastic caps and they are adjustable, but save that for after you try tweaking that middle carb turnbuckle link.
Adjusting the turnbuckle: Can't see the throttle stop/idle adjustment screw on the middle carb but be sure it has no way to interfere with the trurnbuckle adjustment, i.e: keeping the t-shaft from being able to close down the blades further w/turnbuckle.
Well - none of the linkage is attached.
I pulled the middle (offending) carb, and adjusted the throttle plates as carefully as I could for full closure. Still the same readings.
Switched the front & middle carbs…. problem moved up front.
I need a flow bench. I might make one with my shop vac. More work to do this week!
Rocky
hmmm... that both barrels are the same rules out likelihood of bent shaft or plates not seated (since you went back and realigned).
Another thought: is the internal return spring keeping enough tension on the shaft at full closure? Could it somehow have been 'stretched'?
After seeing that air corrector jet in place of a main, my suspicions are raised that it could be possible.
I’m going to try a new spring.
I hear I can get 82* throttle plates to have the plates seat on a different part of the throat.
Rocky
Unless you can see some sort of evidence there's wear at the closure point of the blades to the throats, that two-and-a-bit degrees different angle won't mean much. The plates may be subject to the problem but not the cause, IMO.
Your flow-meter indicated that both barrels are drawing equally, the problem "moved" with that carb, so you've isolated it to that. Something mechanical on that carb is restricting the shaft movement or allowing more volume. It may well BE the bypass screws. But swap out that spring first.
Got the car going, took a 6 mile trip yesterday…. Runs pretty good, needs minor “fettling”!
Thanks for all the advice!
Rocky
Were you able to calm down the "errant child"? If so, what was causing the excess draw?
Yes it was just a subtle throttle linkage adjustment interference problem. Got them ALLto within about to kilograms per hour, Most much closer than that.
Fine-tuning to continue!
That is one of the curses of these linkage set ups. They have lots of adjustability in the set up so there are ample opportunities for something to be amiss and cause an issue. Glad to see it was relatively minor fix, and I'm seeing good progress on your project.
Out and about!
Everything still going along relatively smooth? Glad to see that you're getting the TVR out and about, there's a guy that lives within a few miles of me as near as I can tell with a blue TVR 2500M and I see him out and about in it on occasion.
Looks great, glad to learn it's running well!
Anyone know if it is possible to upload a video?
Only way I know is to upload to YouTube first, then provide a link. Maybe someone else knows a different way.
bravenrace WTB - TVR 2500M TVR 0
O TVR 2500m weatherstrip source needed TVR 2
Z Just Restored 1973 TVR 2500M, Barn Find TVR 24
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Jastx TVR 2500M tires - what are you running TVR 7
M TVR 2500M Model TVR 4
J TVR 2500M Shop Manual TVR 9
D TVR 2500M Parts Car.......For Sale Other British Cars 6
Slider748 TVR 2500M vs TR6 Other British Cars 6
D TVR 2500M wheel question? Other British Cars 3
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
P TVR Big Valve 4.3 TVR 0
T I added another TVR to the fleet. TVR 10
R Old History - List of USA TVR Authorized Dealers TVR 10
J 1985 TVR 280i Speedometer Cable TVR 4
JoeO 72 TVR Vixen hybrid restoration TVR 1
JoeO 71 TVR Vixen V8 Conversion TVR 26
Grantura_MKI TVR owners. TVR 3
M 1963 TVR Grantura TVR 6
2 1972 TVR Vixen 2500 Radiator TVR 6
Grantura_MKI New TVR TVR 2
arcom For Sale TVR T-Slot 14" Rim and Tire Other British Classifieds 0
JPSmit TVR Typhon Spotted 0
Mickey Richaud TR2, TVR Chimaera, MGB... Spotted 8
D Changes in TVR Parts Supply TVR 1
D TVR Tuscan headlining Bows TVR 2
D Nice looking TVR Vixen S2 For sale TVR 1
J TVR engine advice please TVR 7
I TVR shop manual TVR 7
glemon Great Wheeler Dealers tonight, Lamborghini and TVR Other Cars 1
T TVR Vixen TVR 3
B TVR with Essex V-6 engine question TVR 5
Z TVR Tuscan Spin Mid Ohio 2012 Racing 0
Marvin Gruber TVR Value TVR 1
T 1972 tvr 2500 TVR 3
aeronca65t TVR EBay-MD TVR 2
Z Mid Ohio TVR / Watkins Glen GT40 Racing 15
aeronca65t TVR for sale TVR 0
aeronca65t Turkey Bowl-TVR TVR 12
Tullamore Rearended in TVR Vixen TVR 16
aeronca65t Another TVR-NH TVR 1
C Very nice Triumph-Powered TVR 2200 Special Racing 9
R Great Showing of TVR's TVR 4
Jastx Greetings from new TVR owner TVR 7
G Early TVR's@ Amelia Island Concours TVR 2
JPSmit TVR Tasmin Spotted 0
aeronca65t TVR 2200? TVR 11
MadRiver Washington DC -- Black TVR 2500 M Spotted 0
aeronca65t TVR @ NJMP TVR 5
V Nice TVR for sale TVR 3
