Tuning - any expert advice?
Administrator
Boss
Ok, my 78 Spit has dual Webers and headers and a hot street cam. I know it is running rich so I need to re-jet the thing and also I know the timing is not optimal for the set up. Is there any semi-scientific way to get the pproper jets and timing or is it just trial and error?
Bas,
if you are serious about this:
There are books & books written about how to tune Webers. It would take several pages here to cover it all. Below are two good links which give the answers much better than I could do it in a long series of posts.
https://www.triumphspitfire.com/weber.html
https://www.geocities.com/Baja/Canyon/1017/weber.html
A starting point might be;
Chokes (venturi tubes) 34 mm
Main jets 135
Air correction jets 190
Emulsion tubes F15
Idle jets 40
Idle air bleeds F9
Pump jets 40
Aux. vent 4.5
[ 05-11-2003: Message edited by: Dave Russell ]</p>
Yeah -- you can see why some people consider the Weber hard to tune. lot of separate jets & adjustments to get right. Not that much better for power than SU's either. However they do look trick. I think that people choose them more for looks & the Weber mistique than practical reasons. They do have their place for serious race engines.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Dave Russell:
However they do look trick. <hr></blockquote>
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 tuning webbers Triumph 3
jehuie Tuning up a 1275 Spridgets 17
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
D 62 tri-carb tuning question Austin Healey 8
M Carb Tuning Austin Healey 40
M Carb tuning [again] Austin Healey 2
CJD TR2/3/3A SU Carb Tuning Triumph 17
E TR6 Crankcase venting and general tuning advice? Triumph 29
AN6-TX Tuning/Tweaking for Altitude Spridgets 11
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
Martinld123 Tuning H6 100 M carbs Austin Healey 10
R General Tech TR3/4 Tuning Triumph 27
HealeyRick Sprite Tuning Information Memos Spridgets 0
HealeyRick Big Healey Tuning Information Memos Austin Healey 0
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
KVH General Tech Timing and Valve Tuning--with a plastic fan Triumph 4
M wire wheel spokes "tuning" Austin Healey 8
S Procedure for setting and tuning HD8s? Austin Healey 10
C BMC Special Tuning Data Austin Healey 9
KVH TR4/4A Tuning the TR4A Triumph 16
S Tuning the Sprite Spridgets 3
L 100 BN1 Tuning instructions ebay Austin Healey 3
7 General Tech Engine vacuum, tuning question Triumph 7
7 General Tech Tuning an engine with a vacuum gauge Triumph 5
Coyote1 TR6 TR6-tuning new motor with mods Triumph 6
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
T SU HS6 tuning - lifting pin question Triumph 11
M TR4/4A 67 TR4A, any tuning mods with Redline/MMO in gas? Triumph 3
HealeyRick "Tuning BMC Sports Cars" Spridgets 11
Westfield_XI Weber tuning breakthrough Spridgets 14
M Carburetor tuning - setting mixture Triumph 6
Nunyas Saw this at a "tuning shop" Other Cars 0
hondo402000 Tuning my Webers now Triumph 13
af3683 Tuning SU H6 Carbs Triumph 5
drooartz MGB MGB tuning conundrum MG 25
T tuning carb timing Austin Healey 17
Stewart Tuning experts MG 4
PAUL161 Tuning the 1800 engine. MG 5
W Carburetor tuning Triumph 18
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
drooartz Tuning help Spridgets 16
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
M su carburetor tuning Triumph 7
drooartz Progress: a little tuning Spridgets 0
D Wideband O2 Sensor for Tuning MG 1
