A
Aussie_Dave
Guys,
Your thoughts please.
I purchased my car 10 years ago. Ex USA with SU Carbies. Ripped the motor out after the first month and did a rebuild. New rings to the honed original bore size and hardened head valves and guides in preparation of the phase out of lead replacement fuel. I can only get unleaded now. The car sat idle for a couple of years and in February I got it on the road again. I have new front rotors, hoses and stainless sleaved cylinders on the brakes. Just recently it started to puff the occasional blue smoke and since being on the road again it has been using about 0.5 litres (1/2 quart) of oil per full tank of fuel if I use the engine for slowing down. (shifting down to a corner). It occasionally “Diesels on” after turning the key off but again only if I shift down before parking and switching off.
I remember 10 years ago the oil control rings had broken into a couple of pieces.
The bores were good.
Do you know if unleaded fuel affects the Triumph rings?
Can anyone recommend a good brand of rings for the next rebuild?
JP Engineering in Australia have a good name. To get a price from them I need the standard bore size, width, depth of the ring grooves. Does anyone know this? I think the oil control ring setup is and upper and lower ring with a wave shaped centre ring. Is my memory correct?
Thanks in advance for your input.
/ubbthreads/images/graemlins/confused.gif
