TR6 TR6 dual chain sprockets
Yes they will fit, though you will of course need the wider chain tensioner and chain. The timing cover is just the same, so will not need changing.
Hymodyne,
I installed the duplex chain on my Mk III engine with no problems but one: No one seems to put timing marks on the sprockets any more.
By temporarily fitting the timing cover and sliding on the timing pulley, you can "dial in" the crankshaft to 0 degrees @ TDC, visually checking the timing mark on the pulley with the timing arrow on the cover.
Rotating the cam to between the lobes on cylinder #1 (As per the Bentley manual) puts both closed, so I then installed the head. Checking the valves with pushrods in place, I was still on the money, so I removed the cover and pulley and installed the new duplex chain.
One thing I noticed about the sprokets on ebay, it may be the angle of the image, but some of the teeth on the larger sprocket appear to be sharp, while others appear to be dull. Since this is a rotating part that you want to install and forget, I'd pay (and did) the extra dollars and get a new one.
-Bob
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
tr6nitjulius TR6 TR6 N IT That SOUND FEEL LOOK! Triumph 0
K For Sale 1974 TR6 For Sale Triumph Classifieds 0
B For Sale TR6 parts for sale Triumph Classifieds 0
T TR6 TR6 blower motor and fuel gauge won't work Triumph 10
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
Number_6 TR6 Paul’s TR6 Triumph 9
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 5
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
