'74 TR6 - 650 miles since complete rebuild. Ran greqt untill yesterday. All of a sudden lost power like running on 2 cylinders. After several minutes, ran normal then did it again later. Now, does it on start-up. New SU carbs are adjusted fine and getting gas, fuel lines clean and no vent issues. Took the distributor cap off and 4 of the 6 contacts are REALLY badly scored. The rotor tip was scored too. The shaft has no play in it and the cap fits tight with no movement. I dod not remember ever removing the cat after the rebuild but can't rule it out so I don't know if maybe it was not on right. So the question is, obviously it will affect the engine but would it cause the power issue described? I've ordered a new rotor and cap. By the way, it has Pertronix ignotion.
