TR4/4A tr4a irs clunking rear end on fast acceleration
Richard_Brown
First time for this car to really be on the road for over 15 years, most everything has been rebuilt but I am not sure of the rear end, I hear the rear splined axels can bind if not kept lubricated with grease .
Anyone have any other ideas?
It only happens from very slow speed and a quick take off when the rear end squats down a bit.
It could be any number of problems, Differential mounts are broke, diff mounting tabs are broke, u joints,a arm bushings, differential mount bushings, dry splines, loose shocks, rusted and weak frame, loose bolts, shock links, It's time to jack up the car and take a look. Are you a member of the local Triumph club? You should be able to get lost of help from them. I'm sure somebody will chime in with a few more things I missed. Just this weekend I was trying to solve a similar problem. I removed the axles, and a arms and found no problems. I need to road test the car to see if anything has changed, next weekend.
thats what they call the TR Twitch, when the splines lock up on a hard acceleration, especially when you go around a corner, then you let off the gas, the splines unlock and the back end shifts sideways, there could be a noise associated with it.
Hondo
I had that happen on my TR4A IRS and it stumped me for a while. Turned out to be the mounitng bolts for the lever shocks. Just tightened them up and the problem was solved. The thing that made it hard to figure out is that when the car is up in the air the arm of the lever shock is against the stop and that allows the road spring to hold everything tight. So on block in the air nothing "seems" loose when in fact it is (at least on my car it was).
Richard,
I feel your pain. I am still chasing clunks in the rear end of my TR4A IRS. Why Triumph chose to put an IRS system on such a weak, cheaply built car is beyond me. The solid axle version is much preferred. Nonetheless, I love my 4A and am choosing to R&R everything necessary until it's perfect.
Lots and lots of stuff to check. The obvious ones first:
-Differential mounts (check for cracks or stress - best way to do this is with the differential OUT)
-Differential mount bushings
-U-Joints (most common is input to the differential but check ALL, there are 6 - yikes!)
-Slip yokes/slip joints/half shafts
-Wire wheel splines
The less obvious ones:
-Semi-trailing arm mount bolts
-Semi-trailing arm bushings
-Shock mounting bolts
-Rear wheel hubs
-Ring & pinion inside differential (this one is a real PITA to replace if it's bad)
-Shock link
The cars were clunking after a couple of years of use. It's not gotten any better over time.
Best of luck as this could be a gremlin.
Royal
I was getting the same thing, a real head scratcher as I has had it all apart, replaced all u-joints and bushings, checked all mounting poiints and brackets.
I was afraid it was the differential or the diff mounts cracked after install, but I have ust checked the sway bar mount, my addco bar mounts to the in the hole under the spring on the trailing arm, they supply large washers to sandwich around the holes. The top washer is really not big enough, and I found that it had become skewed and slipped through the hole, allowing the mount to move, I got a pair of slightly larger washers, and at least on the the test drive this morning no more clunk.
If you don't have a rear bar this couldn't be your problem, but just another example of check everything as there are lots of possibilities back there.
Royal
Just imagine that. Here it is about 55 years after the car was built and it's still able to be driven...not bad for weak cheaply built car.
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
J TR4/4A TR4A IRS Grille Question Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
G TR4/4A tr4a irs left rear wheel Triumph 14
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
J TR4/4A TR4A IRS Exhaust Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
J TR4/4A TR4A IRS Exhaust Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
gubba TR4/4A My new 1967 TR4A IRS Triumph 17
J TR4/4A TR4A IRS Home Triumph 5
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
RJS TR4/4A TR4A IRS Diff Capacity Triumph 3
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Darrell_Walker TR4/4A TR4A IRS-SC?!?!?! Triumph 48
KVH TR4/4A TR4A IRS Differential and Axles Removed Triumph 11
KVH TR4/4A TR4A IRS Issues and Smashed Thumb Question Triumph 24
KVH TR4/4A TR4A IRS Axle Shafts Triumph 19
KVH TR4/4A TR4A IRS Rear Spring Bridge Triumph 6
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
T TR4/4A TR4a IRS differential mount issues Triumph 11
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
