TR2/3/3A TR3 Oil Pan Gasket?
mountainman
My oil pan is leaking bad. I am goiung to put a new cork gasket with high temp scilcone sealer on it and was wondering if I should put the sealant on the pan, let dry and then put some sealant on the block also? This is my second go around with this. First time I made sure the pan wasn't bent and just put the sealant on the pan.
Thanks
Greg
Greg -
Been covered before, but take a little extra time and ensure that the mounting holes of the pan are perfectly flat. Over-tightening causes dimpling of the thin metal, and, of course, leaks.
Small hammer, nice flat surface to work with, and tap them gently back into form.
Sounds to me as though there is something else wrong. The sealant helps, but it shouldn't leak "badly" even with nothing at all.
Are you sure its coming out past the pan gasket, and not say, coming out the front seal and being blown back along the pan/block joint? I've also had trouble with the fuel pump/block connection leaking oil, and looking like the pan gasket was leaking.
Hey mountain man oil leaks are a pain and often difficult to tell their origin. It might be leaking above the pan, perhaps the front bridging piece is missing its gasket or maybe the pan itself is cracked. I have seen both those problems. I would try an assertion the origin first. Try fogging some baby powder in the suspected area after you wipe it down good. Those oil pans crack when people jack the car(po) up from them or a big rock or whatever.
Steve
I did check the other possablies of the leak and it is the oil pan around three of the rear bolts. I also made sure the pan is flat. What would be the down side of putting the sealent on both sides?
Greg
Greg-
Well I know the racers have no problem using silicone sealant like that, but I'm not sure you need to have it set up first. Tony Drews, for example uses Permatex Ultra Black: rebuild shots.
I found his website a pretty useful visual reference of getting the engine back together, and also wound up using Ultra Black on the pan gasket. Will know probably in a couple of months if it actually worked.
Given a rear drip though - have you completely eliminated the thought that you are leaking from the rear main cap? That felt material was a major messy pain to install.
Randy
Hey Randy,
I have checked and double check and thank goodness my only leaks now are the oil pan. I think I'll try silicone on boyh sides of the gasket. I'll post how it works out.
Thanks
Greg
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A Average life span of a TR3 Coil Spring? Triumph 5
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
M TR2/3/3A TR3 aluminum oil pan Triumph 9
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
newmexTR3 TR2/3/3A TR3 Oil Pan thread repair Triumph 6
RedTR3 TR2/3/3A TR3 Oil Pan Gasket Triumph 9
P TR2/3/3A TR3 Oil Pan Leak Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
B TR2/3/3A normal oil pressure in TR3 Triumph 6
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
J TR2/3/3A TR3 coil spring height Triumph 4
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
G TR2/3/3A TR3 Oil Strainer Repair Triumph 6
S TR2/3/3A old style tr3 coil Triumph 4
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
P TR2/3/3A TR3 Transmission oil Triumph 13
M TR2/3/3A TR3 oil filter cap needed Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M TR2/3/3A Pertronix coil for TR3 Triumph 7
J TR2/3/3A TR3 oil pressure hose question Triumph 1
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
af3683 TR2/3/3A TR3 Coil Questions Triumph 3
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
A TR2/3/3A WHAT IGNITION COIL TO BUY FOR MY 59 TR3 Triumph 10
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
K TR3 Oil Temperature readings Racing 2
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
PatGalvin TR2/3/3A Target Oil Pressure for new TR3 Rebuild? Triumph 4
S TR2/3/3A tr3 tranys oil Triumph 10
