TR2/3/3A Tr3 frame work finally
Graham H
Spot on Tush I always say if you start with nothing and finish up with something you have to be miles in front.
graham
Tr3aguy
Tr3aguy
Got another hour in this morning and getting closer...
Tr3aguy
Tr3aguy
So today I noticed I had a slight rise at the end which was making it not square.... after some more grinding the fit was much better.
Then I proceeded to coat the interior with some paint and drill for simulated plug welds. I broke out the welder and got two spots welded, took off the vise grips and dropped the piece. It popped right apart..... sigh. Check my settings and moved to a little hotter weld and slower wire feed, that did the trick.
Now here I am test fitting after joining the two pieces
Now I am relaxing cuz the shoulder decided that today I was done. So clamped it on and made a few more adjustments to the fit. It seems crazy how heat from welding will move a part around.
I doubled checked my measurements for height and it was spot on.
All in all a pretty good day in the garage.
JP
sp53
JP that looks extremely nice. I would have used the plug weld method also. It was how I was taught. I see guys with sheet metal doing a butt stich weld and I am learning that more. IMHO the plug weld gives that lapping strength like in carpentry. Anyways, on my project I am going to use wax oil or some product like that for the inside of the frame and the back of the tub where the tub has those trapped sealed areas; it seems to work well in the climate I live in plus I can put the wax oil in through the holes in the frame on the sides where the brake clips and in other holes anytime and after I am done and in the future; Good job JP!
steve
Tr3aguy
Tr3aguy
Ok so I think not too bad for my first time welding in a bit. Finally got it all attached and trimmed up. I do see a few pinholes that will need to be addressed. It is a whole lot better than what I had there....
I have to make a cap for the front and get to the side piece that is missing part of the tube for the rebound bracket for the front suspension.
have a fun day
JP
thanks for all the kind words even thought to me my weld look like hills and valleys!
Frank Canale
JP, Great job, the spot welds look like you got the heat into the bottom piece and should hold just fine. As a welder I am never satisfied with my welds. I always say they could look better. I looked thru my discarded parts that have been repaired and found the area for the bump stops. I rebuilt that area completely and have the old bump stop tubes. If you are interested I will be happy to send them to you. Send me your address in a PM and I will get them on the way. Frank
M_Pied_Lourd
Looks better than my repairs. Great job.
Cheers
Tush
sp53
JP that is super clean; nobody will even know you fixed after it is painted. The end cap piece came from the factory with 3/8 hole drilled in it. Not sure why maybe a vent for moisture, so there are holes all over the frame. Like I said, I use wax-oil for the inside and put it in later. You are almost ready to putting the spring pans back on after you paint and clean up stuff.
For paint on the frame, I used single stage paint for metal that has a zylene base. Sprayed most of it, but brushed it on also in those weird spots. It is inexpensive maybe 45.00 a gallon. Zylene itself has an oil base so you cannot use it to clean metal like you can with lacquer thinner, and you can thin with zylene to help spray it. The zylene paints are easy to work with and stay a little softer, so they do not rock chip and they dry quick. Was that Frame yellow from the factory.
After getting the spring pans on many of the other things fall into place easier. Are your lower wish bones straight? Give them a good eye ball first before you start working on them because they are often bent at least one of them; they hang low and get hit hard.
steve
Tr3aguy
Tr3aguy
I am hating this cold snap because it make me not be as motivated in the garage. I am thrifty so I save my file 13 mail in case I need to mock up a part for size. It has to be stiff and decent like card stock. This particular one was “Ford” advertising how they would make a few months of payments for me. Hahah ok
So I save metal of different sizes and I think this one will work just fine!
Tr3aguy
Tr3aguy
Franks thanks for the comments, I will send a PM do you by chance have any pictures of the repair work. It is such a tight little space to get in. I would be interested in seeing those.
Graham H
JP, when I made end plugs for the front of my chassis ,the outside edge is folded out all the way round so it forms a doubble thickness and I welded around the outer front edge. If you try and fit a flat plate inside the rail you won't be able to dress your weld after, I think the end plate may have been originaly spot welded at the factory.
Graham
Tr3aguy
Tr3aguy
I am not sure I completely believe that David but thanks for the fuel to keep me going!
Cheers
Tush
Tr3aguy
Tr3aguy
Not sure I completely understand what you mean by folded out. Do you have a closer picture of the piece you made? You frame looks spectacular? Is it finished now?
GrahamView attachment 63612
Graham H
I have made a not to scale scetch which I hope will give you a better idea of what i did, the dotted line less the thickness of the plate will be the exact size of the inside of the chassis after you bend the tabs at right angles. I didn't put the hole in the middle I couldn't see the reason for it.
I reassembled and road registered the beast in Jan 2012 so yes its all back together.
Graham
Frank Canale
Excellent description of how to form the end cap. Most people forget to allow for the material thickness. Frank
Graham H
JP, I see your photos are sideways and upside down, I had the same problem if you are using an iPhone and you take a horizontal shot the volume buttons need to be at the top and if you hold the phone upright the lens needs to be at the top. This website is Windows based and won't orientate the pictures from an Apple device so if you hold the phone upside down that is how the picture will come out on here.
Graham
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
Jim_Stevens For Sale TR3 Free frame Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame repairs recommendations Triumph 29
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
O TR2/3/3A TR3 Frame Repair Triumph 1
J TR2/3/3A Frame differences in a TR3?? Triumph 17
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
T TR2/3/3A What gauge steel use for TR3 frame? Triumph 3
B TR3 seat frame issue Restoration & Tools 2
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
CJD TR2/3/3A TR3 Hood Frame Triumph 2
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
mgedit TR2/3/3A Body back on Frame [56 TR3] Triumph 11
G TR2/3/3A TR3 Replica With Space Frame Triumph 13
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
M TR2/3/3A Which frame is correct for early TR3 Triumph 18
HealeyDave TR2/3/3A TR3 Frame Source? Triumph 2
PatGalvin TR2/3/3A Tips for fitting tub on TR3 prepared frame Triumph 23
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
mountainman TR2/3/3A Tr3 Top Frame Webbing ? Triumph 20
D TR2/3/3A Frame Question TR3 vs TR3A Triumph 5
luke44 TR2/3/3A TR3 Frame Dimensions Triumph 9
B TR2/3/3A Question about bad welds on frame 57 TR3 Triumph 6
B TR2/3/3A 57 TR3 Still fighting window frame holder oner's Triumph 6
mountainman TR2/3/3A TR3 FRAME PROBLEMS HELP PLEASE Triumph 11
mountainman TR2/3/3A TR3 Windsheild Frame Question Triumph 8
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
mountainman TR2/3/3A Refinishing TR3 Frame Triumph 13
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
M TR2/3/3A TR3 Windshield Frame Triumph 2
G TR2/3/3A TR3 Frame Kit Triumph 4
gsalt57tr3 TR4/4A TR3 on TR4 frame Triumph 5
S TR2/3/3A Tr3 frame about done Triumph 6
S TR2/3/3A shocks on a tr3 frame Triumph 16
S TR2/3/3A Body to frame tr3 Triumph 4
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
V TR4/4A tr3 body on a tr4 frame Triumph 7
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
