TR6 Toyota Transmission conversion
jhedge
Hello to all.
I am in the process of converting Tr6 4 speed to a Toyota W58 using HVDA Kit. However my mechanic purchased MK3 Model. Toyota has discontinued conversion part number
33502-14100 shown below. Does anyone know where I can purchase the needed part to convert shifter to correct position. Any help would be appreciated.
Joe H.
Have you spoken to Herman? He should be able to help.
I hope you know to change that piece you have to split the trans Herman is a very nice man to deal with but get him on the phone to talk to him you might not have to change that piece his shifter extension might work I hope your mechanic reads all the directions first and go over the video the measurement for the shims is very important go to Bob Danielsons site he goes through it step by step very informative there are a few tricks that make it somewhat easier not a hard conversion but lining up the splines can be a bitch
Joe,
you say that you need a Toyota part. But Herman's kit includes the actual part that you need. It is a part that Herman makes it is not a Toyota part. If you have the wrong kit from Herman you need to work with him to exchange that part or parts to get exactly what you need. He has the kits for these cars, you just need the correct one.
Most often our interactions with somebody like Herman are hampered by our own lack of understanding what we really need.
But Herman's kits are complete. Or at least the five that I have worked with were.
It may be possible to have your part modified. Cutting and welding to eliminate the extra length in your shifter housing. Take a look at this link. Yes they are doing the opposite of what you need to do. They have extender their shifter. But the process is the same.
https://www.google.com/search?q=SC3...iw=1280&bih=592&dpr=1.5#imgrc=LqD6A1TOY6TiyM:
In this picture. The smaller part is what you need.
https://www.celicasupra.com/forums/showthread.php?56444-Mike-s-(Supersubs-s)-Big-Boy-Build/page62
The W58 appears to be a very popular transmission for Japanese hot rods and rock crawlers. At least one post I read mentioned people wanting to put a W58 into pieces of crap like an MGA. The general impression I get is the guys who are looking to put a W58 into a rock crawler or a later model Japanese car require the longer shift housing. It wouldn't surprise me if they are throwing away the part you need.
I think you are right about the conversion piece. The Tuner crowd is probably discarding the piece I need. Welding is my last resort but if necessary will do. Will check with Herman first or join the celica site and see if any out there may want to trade.
Thanks for your help.
Joe H.
I just did this conversion on my TR4 and the site you mention is pretty much spot on to the instructions Herman gives in his kit. I bled mine and it seems perfect. Now...just need to get her running so I can actually drive it and try the conversion.
Cappy Toyota 5 Speed transmission Austin Healey 4
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
T TR2/3/3A TR3A transmission to Toyota trans Triumph 1
Michael Oritt Transmission oil specification--Toyota box Austin Healey 10
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Cappy Toyota 5-Speed Austin Healey 3
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
Michael Oritt Toyota 5-speed Problem Austin Healey 28
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
S '81 Toyota Celica Other Cars 8
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
aeronca65t One less Toyota 2000 GT Other Cars 5
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
M Toyota 5 speed Shifter Austin Healey 2
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T TR4/4A Toyota calipers for a TR4A Triumph 18
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
M synthetic fluid in a toyota 5 speed? Triumph 20
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
prb51 Tr Toyota 5 speed upgrade Triumph 24
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
