Transmission oil specification--Toyota box
Michael Oritt
The labels on the transmission oils available to me say that they are either GL-4/GL-5 or just GL-5 spec. The Red Line site (https://www.racerpartswholesale.com/redtech4.htm)
says that GL-5 spec is bad for the life of brass syncro rings on most transmissions and points to their MTL or MT90 oil. I can't find Red Line in my local stores--does Red Line's claim seem to make sense or are they simply creating a niche for their product? This is for a Toyota 5-speed box.
Okay Jedi Wannabe I'll be happy to share my experience with the Redline products.
I've used MT 90 in my Toyota Camry V6 with a 5 speed gearbox. Shifting has improved.
I'm also currently using the 75-90MTL multi-vis is my Healey 3000 and shifting has slighlty improved over engine oil. Since it also smells different than regular engine oil, diagnosing source of leaks is easier.
Redline is also more costly over the alternatives - what you woud expect from a superior product. Hope this helps. Gonzo /ubbthreads/images/graemlins/thumbsup.gif
My gear box sceamed in third gear and I had trouble shifting when outside temps were high. The Red Line product MT-90 has made about 90% improvement and it seems like it is still improving with miles. Forty bucks is a very cheap fix on a Healey!
Michael,
Try your local speed shop. I found it at a place called Speed Merchants in San Jose. Seems like racers use Redline
alot. They had it on the shelf. It also turns out to be a great source for poly bushings, aluminium and steel fuel lines and other aftermarket goodies. I found that two pieces of 60 inch fuel line (plus one union) is the exact length needed for replacing the pump to carb line on a BT7. And it came straight not coiled. So roll a pack of Viceroys in your sleeve, put your hand on the chrome skull shift knob and head on down. We know your just a gearhead spped demon at heart anyway Mike. grin
Michael,
Using the Redline oil in my Healey trans made the shifting noticably smoother and the worn first gear much quieter. It also worked very well in my VW golf that had high milage and was notchy when running through the gears.
You can search for dealers in your area by zip code at the Redline site ....
https://www.redlineoil.com/dealers.asp
Cheers,
John
[ QUOTE ]
Michael,
[/ QUOTE ]
John--
My zipcode is EEIIEEIIOOOO. The dealers (Advance and Autozone) in Prince Frederick are listed on the website but they never stock it.
[ QUOTE ]
[/ QUOTE ]
I guess the tractor owners haven't been clamoring for it (they don't know what they are missing). You can always mail order it directly or from the distributors in Ohio, Baltimore, etc. Looks like some will tack on about $8 - $10 for shipping/handling. Or you could just pick some up on the way to Conclave!
Cheers,
John
Moss used to carry it and perhaps they still do. It is pictured on page 25 (front 'car care' section) but there is no listing to go with the picture.
When they had it I think they only carried 75W90 NS, whereas you may want something more like MT90.
Since I'm leaving for Conclave this coming Sunday I had to use what is on hand--a synthetic 75/80 with GL4/5 spec. Thanks everyone for the input--in the future I'll mail-order some Red Line in advance.
A little late, but another "hey this stuff works!" comment. My tranny shifts better, etc, too. I contacted Red Line and they told me the closest dealer which turned out to be less than a mile from where I was living at the time! Good luck on your drive, Michael!! See ya at conclave!
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
EWD TR6 Transmission Oil Seal Triumph 13
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
TomMull TR2/3/3A Transmission oil leak Triumph 17
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
vette Transmission Oil Austin Healey 5
M What is the proper oil for Bugeye engne and transmission Spridgets 6
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
T Transmission Oil Austin Healey 7
R transmission and rear end oil Austin Healey 2
P TR2/3/3A TR3 Transmission oil Triumph 13
bobh Changing Transmission Oil in 10 minutes Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
T 1275 transmission oil leak Spridgets 2
M Transmission oil Spridgets 2
Jim_Gruber Transmission Oil and Differential Spridgets 3
J location of transmission oil filler on a BN-2 Austin Healey 5
PAUL161 Transmission oil Type MG 3
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
TRnorwegian Easiest way to check refill oil in transmission? Triumph 20
AUSMHLY Another transmission oil question Austin Healey 19
66healey oil for transmission Austin Healey 2
dklawson Transmission Gear Oil - Synthetic? Triumph 7
Stewart Leaky transmission oil drain plug MG 3
R Best gear oil for transmission in midget[snail] Spridgets 3
R 1500 with OD transmission oil recommendations Triumph 15
martyc MGB MGB Transmission Oil -- with Tasty Metal Shavings MG 2
ronzet Transmission Oil Recommendations Austin Healey 8
M Transmission Oil Spridgets 13
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
G Changing front oil seal on transmission. Triumph 14
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
ronzet Oil Viscosity Transmission Austin Healey 17
nevets transmission/OD oil question Austin Healey 17
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
T How full to refill transmission oil? Spridgets 4
gbtr6 Transmission Oil/Lube Triumph 4
cdsmith Transmission oil? Rear end oil? Spridgets 15
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
B transmission oil?? MG 10
S TR2/3/3A Tr3 transmission oil Triumph 4
Johnny Transmission oil seals Austin Healey 8
S Transmission oil filler where is it? MG 5
R transmission oil Austin Healey 4
G Transmission oil dilemma Triumph 6
D Transmission oil pump question MG 2
7 Transmission Oil Refil MG 3
