Torque settings and extensions
prb51
Often I can't get to a nut/bolt without an extension on my torque wrench. I've had some mechanics tell me they swag some additional lbs. depending on the length of the extension. i.e 5 ft.lbs for a 3" ext. etc.
What say you?
Mickey Richaud said:
Good question!
Found this when I rebuilt the engine for the TR8:
https://www.norbar.com/torquewrenchextensioncalculator.php
Mickey
In the case noted in the link, that applies when you are actually extending the length of the torque wrench. What the OP is asking about is putting an extension on a socket, and then torquing the bolt. I don't have an answer to that question, but knowing if the extension has an affect would be important to know. And then how in the heck would you calculate that?? All extensions are NOT created equal. Some will twist more then others even if they are both 1/2" or 3/8".
So, who out there has the answer??
Edit: Mickey had the answer before I got my post up. Well, this is good to know.
Hmm... Seems easy enough to determine the amount of torque lost to the extension.
Torque bolt without extension to 75 ft.lbs.
Now remove the bolt with the torque wrench with extension set at 75. If it clicks before it releases, then bump to 76. Continue until it releases.
The difference should be the amount of torque absorbed by the extension, right?
Nope. It takes substantially more torque to start a bolt moving than it takes to keep it moving. The difference is commonly called 'stiction' (from "static friction"). If you just torque a nut to 75 ftlb, then set your wrench to 80 ftlb and try again, usually the nut won't move at all. But if you mark it's position, then loosen it and tighten to 80, it will have turned farther. This is why, when you retorque head nuts, you should loosen them slightly first.
Twist is not the issue (assuming you are using a steady torque wrench and not an impact wrench). However, contrary to the link Mickey posted, I believe there is an effect that makes using an extension slightly less effective. By moving the plane of where you pull on the torque wrench handle away from the plane of the bolt head, you introduce a bending moment that I think increases side load on the bolt and hence increases friction. The way around that is to support the head of the torque wrench so there is no extra side load on the fastener (which is good practice anyway, IMO, since otherwise it tends to rip the socket off).
But since bolt torque is a very inexact measurement of what you really want to know anyway (clamping force), I doubt it makes much difference.
Oh yeah, I believe the other link was mistaken as well. Adding a lateral extension even at 90 degrees does change the applied torque. What's important is the length of the lever arm from where you are pulling on the wrench to where the bolt/nut is. So adding a link at 90 degrees increases the torque, because it moves the handle farther away from the pivot point.
I just knew Randall would have an answer when I started reading this.
The twist in the extension does not matter as long as you are raising the force slowly enough to be in a static situation. The socket extensions the gas stations use on impact wrenches are dynamic devices and depend on calibrated flex in the device.
SHEESH! This is why I'm a priest! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
No. Adding a lateral extension at 90 degrees does not change the applied torque. It does not change the arm, so it doesn't change the torque. I used to teach this in A&P school. One student didn't believe me. He made a bunch of different length lateral extensions at home and we tried them on a torque wrench on our torque wrench calibrator. The lateral extensions did not change the torque when used at 90 degrees.
Me too!
Wanna complicate it further, try having to use a crow's foot with your torque wrench, like on a header, etc.
Same thing, Bill. Just turn the crow's foot to 90 degrees to the torque wrench handle and the torque won't change.
After further consideration, I see you're right, John ... IF you add the caveat that the force applied to the torque wrench is only at right angles to the wrench itself. But pushing on the end of the torque wrench will apply torque to the fastener without changing the reading at all.
Hedge yer bets, Randall.
THANK you, John!!!
/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Errrr....my head hurts, where's me spanners...
Very good stuff, specifically the 90 degree addition as that will work in some tight spaces.
Ok, that was easy for you guys so...
If a train left Chicago at 2:30pm and traveled at 60 mph how ....I always hated those boogers.
Hmmmmmm.....
Twosheds and the others that state there is no need for any "adjustment" for an extension at 90 degrees are correct. I sold torque wrenches as a Snap-On dealer for 19 years. People that say that once a fastener is "bottomed", a second pull will be misleading. An extension WILL absorb power from an impact tool, but not a torque wrench. Frankly, given the allowable tolerances of a torque wrenches, one should be more concerned with the quality and accuracy of the torque tool you own than a minuscule error that could be created by an extension.
Bob, now that is valuable advice!
Ever compare types of TQ wrenches?
Scaaary sometimes.
Advice: Get yours checked/calibrated!
Just my .02
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Stewart Torque settings MG 4
I 60 Bugeye front suspension torque settings? Spridgets 4
Bruce_B Torque settings? Spridgets 1
S Torque settings? Spridgets 4
B Torque settings? Austin Healey 2
mbrooks 100 Exhaust - torque settings, gasket sealant?? Austin Healey 3
U Torque Settings Austin Healey 1
tahoe healey torque settings Austin Healey 11
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
