Top to window seal problems
jerrybny
OK I'm back after spending a good amount of time trying to get the window seals installed. No Matter what I do I can't seem to get the rubber seal to press up against the glass. I'm not sure what I might be doing wrong but I'm at a loss. I was hoping someone could take some good clear pictures showing the side of the window. I would like to see how the top looks where it veclros to the frame and then also some good clear pics on how the rubber seals and channel meet the window. I would appreciate if anyone can do this. Got caught in the rain the other day and water was getting inside. /ubbthreads/images/graemlins/cryin.gif Also does window close up against the bottom of the channel or side? Maybe my frame is bent?? theThanks
Jerry,
Adjusting a top to be a really good fit can cause a, well, fit! There are a number of things that can be adjusted on the top as well as the windows themselves. First off, the hinge mechanism that bolts into the B pillars is adjustable for starters, as the receiving nuts inside the posts are floaters. This will give you some latitude in the whole position of the top. Also, the tighter the top fits on the frame, the better off you are. I have actually resorted to un-gluing the front rail (by pulling slowly and hard for a long period of time) and restretched the top by 1/4". The tightness of the top dictates how good the frame arches and the fit of everything. Next thing to look at, and it is a PIA, is the attitude of the windows themselves. You will have to remove the door panels to get to them but the frames that hold the window glass are adjustable as well as the whole position of the glass. You can actually make the glass move fore or aft with adjustments. TRF sells an extra large piece of rubber sealant that will glue right next to the stock front glass rubber seal on the windshield frame that will seal the front of the window glass nicely and not look out of place. You have to ask them for it. Also, sometimes frames are just plain worn out and need all the fasteners redone.
Hope this helps.
Bill
There is another item that is adjustable that Bill did not mention they are the channels that hold the seals in place over the door glass. I have just spent the last couple of evenings installing new Velcro on my top frame so this is all fresh for me.
Before I did this my windows would not seal either. The channels that hold the seals are adjustable both fore and aft and inboard to outboard. If your seals are not contacting the glass then you will want to move the channels outboard assuming the glass is positioned correctly.
Remove the rubber seals from channels and then loosen the screws holding the channel to the frame. Adjust the position, reassemble and check the fit repeat as needed.
The window should close against the side of the rubber seal and not contact the channel at all. The profile of the seal that looks like the barb end of a fish hook should face out.
Good Luck! /ubbthreads/images/graemlins/hammer.gif
Bill, have you found any instructions on how to adjust the windows? I looked in my Haynes and Bently books and neither have any instructions on out ot move the window in or out. I'm guessing I need to move them in as I have put the channels as far outward as I can and there is still a gap where the glass should touch the rubber. Thanks
Jerry,
Take the door panels off and look inside. I had to change my channels and completely rebuild both mechanisms so I got a feel for how the windows work. It might behoove you to take your windows apart (I know this seems like a PIA but really not that tough. Also a good time to grease the lower channel and inspect your lateral channels. They are available new and really not that expensive.) All the bolts are adustable and therefore the whole thing is adjustable.
Bill
M Zip-Out Rear Window on a BN-7 Top? Austin Healey 11
Lutz Kramer Soft Top Zippered Window Austin Healey 5
M TR4/4A Microplas Surrey Top.....Window Help Please. Triumph 22
Rut TR4/4A Who makes a good top with a zippered rear window? Triumph 2
D How do I clear up a plastic rear hard top window? Restoration & Tools 3
D BT7 Hard top back window that is very cloudy Austin Healey 5
cmacmillan TR6 TR6 Top rubber window seals Triumph 13
memphis Soft top to window adjustment? Austin Healey 32
G Hard top back window rubber Triumph 5
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
R window doesn't fit top opening Austin Healey 17
dklawson Spitfire MkIV Spitfire Convertible Top - Window Seals? Triumph 2
M Midget Top - Rear Window needs help Spridgets 2
jvandyke soft top window stains Spridgets 3
RickB Another soft top question - zip out rear window? Spridgets 43
jjbunn Window Soft Top Fitting Triumph 12
J New Soft-top, or reupholster cracked window? Triumph 6
PAUL161 Question on L shaped rubber top of window channel MG 10
2 How to cleam plastic window on conv top Restoration & Tools 40
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
