MGB Tire pressure for 1980 MGB
jr234
Hopefully this should be a real easy one...My 1980 MGB has alloy wheels and 205/70/R14 tires. The manual refers to a slightly smaller tire on that rim (185/70/R14). The recommended pressure for the 185 size tire is 21 psi front and 26 psi rear. I inflated to that limit. I received a suggestion that perhaps the car would handle better if I inflated the tires (all four) to the max allowed psi on the tires (35 psi).
Call me paranoid, but it seems inflating to that max is asking for trouble. Any thoughts, or should I leave it at the manual's 21/26 recommended inflation? Appreciate any opinions.
Platinum
Try 28 front, 32 rear as a start.
J
jr234
I appreciate the feedback. I'll give those tires the extra inflation and see how it drives. Having just gotten the car back into running shape and shifting shape, this will be another revived experience!
Have a happy and safe Thanksgiving holiday!
YakkoWarner
My experiences (and note I am neither tire professional nor a professional driver) are that firmer pressures do seem to handle better. Even in the past 10-15 years tire design has changed a lot - I remember tires having a 30-35PSI max rating written on the sidewall. Almost every tire I've gotten in the past 5 years has had a max rating close to if not slightly over 50PSI. Running those tires at 26-28 is not fun, you can feel the sidewalls compressing down in a turn and it gives a lot of body lean. Using higher pressure gives a more positive feel, steering response becomes crisper and roll and sway decrease.
The other side of the equation is that firmer tires transfer more impact to the suspension in regards to bumps and holes. Higher pressure can reduce the size of the contact patch and mean less overall traction.
Excessively low pressure can also reduce traction because the edges bear more weight than the center of the tread surface.
Running higher pressures can shorten tire life because the center wears more than the edges
End result is that I trust the tire manufacturer with regard to pressure. The people who designed and spec'd the tire pressures on older cars had never seen tires like we have today. Those specs are exactly correct for the tires the car was designed with, but not only are sizes different now but the whole construction of the tires is different. I (possibly incorrectly) trust that whoever designed the tires knows more than I do with regard to how its designed. I usually start with a little under the max rating of the tire and see how it feels both in terms of traction and handling response, and adjust downward if they seem to lose grip too soon. And keep and eye on them as you drive - if you see the center wearing more than the edge you have too much, if the edges are wearing away too soon you have too little. On my truck I usually have the back ones down more than the front unless I'm carrying heavy stuff - otherwise I wear the centers out too soon and truck tires are expensive.
Bristol401
Member
NEVER set tire pressures to the max stated on the tire. It’s called the max for a reason. Run at the pressure stated in the car’s manual. For better grip in turns.. drop pressure. I ran my Lotus Super 7 at 18 psi, after laps on the track and checking temps across the tread on all 4 tires. Won the ‘98 Sonoma Wine Country Classic with that setup. Trucks and full size sedans will definitely need more pressure than that.
J
jr234
You will have better grip at lower pressures. Oversized tires will tend to have less contact patch at the same pressure.
Bristol,
Thank you for the reply. I agree with your observation about the relationship between grip and pressure, as well as the size of the tires. As I mentioned in an earlier post, the MG manual (assuming it was the original with the car) is nearly 45 years old, so the tires I have were not even in the table for tire pressure/size and wheel type.
I went with the suggested increase of PSI, 28 front and 32 rear, and I'll keep an eye and ear out for how the car handles on city streets. I was leery about going max on both front and rear (35 PSI on the sidewall) as it didn't seem to leave much room for error. I've also received feedback that 32 on both front and rear would work, and that may be something to consider if the car handles better with equal PSI.
J
jr234
Jedi Warrior,
Appreciate the response to my question on tire PSI. I try to keep all my vehicle tires checked (monthly or thereabouts) to keep them at the manufacturer's recommended setting. Of course, the difference is, my other cars are a MINI Cooper S and a BMW X-3, so the handling is quite different than a 1980 MGB! The MG manual didn't conceive of modern (today's modern) tires, so I was fortunate to have several folks with experience here in the forum and elsewhere give me some ideas of the pros and cons of inflating the tires to meet safe and enjoyable driving.
The MG hadn't been driven in several years, sitting in the garage, with some engine problems (needed to replace the carbs) and then clutch cylinders to permit shifting (without leaking all the brake fluid out of the system). I have taken the MG out on the neighborhood roads (top posted limit is 35 MPH) to see how it runs and ensure the leaks are fixed. Everything appears to be okay (still needs some tweaking, to be honest), but the handling is obviously not what I'm used to in my other cars. I'll attribute that to the unfair advantage my other cars are designed for different driving situations and the MG doesn't have modern steering conveniences. I'll continue to see how the car feels around town and adjust the PSI if it seems to need it.
Thanks again for the info and suggestions.
Platinum
As stated, the 28/32 suggestion is for a start. Observing wear patterns will tell whether the pressures need increasing or decreasing over time, in most driving conditions. If doing something like autocross, the seat-of-the-pants and times will be more revealing.
In the case of Bristol's Seven, it weighs slightly more than nothing, so low pressures are fine. I was usually told the Elan needed to have more than the 18/22 I'd show up with, made me inflate to something that would make the car handle like it was on ice! So "clandestinely" I would lower them back down... lots of F.T.D. times were turned. Optimal pressures are determined by a number of factors. It would seem the O.P. has driving around casually as the plan, hence my 28/32 suggestion as a "base" considering that MG is ±2,500 lb. and the 205/70's are wide enough to show/see wear patterns quickly. Trying different settings based on that wear, for differing driving conditions is the way to go, IMHO.
P.S... the 4-ish lb. front/rear bias on the MGB lends itself to slight oversteer. Much more desirable than scrubbing the nose out from under it!
J
jr234
Dr. Entropy,
I don't expect to see any significant wear on the tires in a short term, as I don't anticipate a lot of driving. I certainly don't plan on getting involved in road racing or that sort of thing, just an occasional local drive to the store on a nice day sort of thing. Once I feel comfortable that the work we've put in to getting it road worthy is sufficient, we may take it on an occasional short road trip beyond the neighborhood.
I imagine the Brit Car aficionados might cringe to hear my limited use of the MG, but after the problems I have had with the car, I feel safe is better than sorry, and I can't keep calling AAA for a tow home. Now that the weather here in South Florida is getting a bit less hot and humid, taking it out more is highly likely, and that may give me the confidence to extend the driving range.
You mean you won't be one of those guys who make the news doing donuts and lots of tire smoke in an intersection, with 20 other guys hanging off the car?? Well, I for one am disappointed......
J
jr234
Hi, Mike,
I would gladly perform the feats of deering-do in the MG, however, here in SoFla, there is a long waiting list on most nights at the intersections for a variety of attempts to overcome the laws of physics (two objects occupying the same space simultaneously). :giggle:
Back when I was "taller" (i.e., a lot younger), I had my share of unintended moments of sheer terror, both involving driving home from college. I was allowed to borrow my dad's 1966 Chrysler, winter time. As I approached a curve leading into a bridge, I hit "black ice" and did several 360's across the bridge. No oncoming traffic and by the grace of God, never touched either side of the bridge. The other incident involved me driving home in the spring from the same college (Wichita State) in my '65 Corvair. It was the same country road, no traffic, and a long downhill stretch. I decided to see what the Corvair could do, especially with the help of gravity in my favor. As the speedometer headed into the 90 mph range, I became confused, as the horizon started to drop below the front of the hood. It took a few milliseconds, but I realized the front end was rising off the ground. Again, that higher authority was co-pilot, and I was able to slooooowly lighten the foot on the gas pedal and the wheels were straight aligned. Never did that again.
I've had other "moments", involving piloting an assault helicopter on missions over Laos, but that's another story.
Administrator
Boss
Since this topic is a specific question related to the MGB, I have moved it to the MG forum. I'll leave a "redirect" in the Pub for a couple weeks. If you're reading this now, you are in the MG forum.
J
jr234
DrEntropy,
Update on the tire pressure issue...a couple of weeks ago I took the MG out to fill the gas tank, got about a block from the house and the rear passenger tire blew, totally shredded. It wasn't the tire pressure setting (IMHO), it was the years of the tires on the car, in the garage. The tread on the tires were quite ample, but as we know (and I ignored) environmental forces deteriorated the rubber. Instead of getting fuel, I had to order replacement tires, ordered 5 as I assumed the tire in the trunk was also of similar material deterioration. The tire techs at Costco set the pressure at 32 all around, but I'll keep an eye on the wear patterns if adjustment is indicated.
Haven't put much mileage on these new tires, but everything seems to be working satisfactorily as far as the relative comfort of the ride and handling. Thanks to everyone who voiced experience advice.
Platinum
A couple things... The Port St Lucie Fair kicks off this week and on Wednesday the "Texas Trick Riders" will be there. Good trip a bit north in an MGB!!!
...and we may need to gossip about things S.E.A.
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
NutmegCT T-Series tire pressure? MG 8
NutmegCT tire pressure gauge accuracy Restoration & Tools 21
NutmegCT TPMS - Tire Pressure Monitoring System Other Cars 9
sundown TR6 TR6 tire pressure Triumph 4
T TR2/3/3A tire pressure Triumph 18
bighealeysource Tire pressure recommendations for tubed tires Austin Healey 4
Nelson Autocross tire pressure?? Spridgets 4
R Glove box tire pressure plate Triumph 5
G Auto cross tire pressure Spridgets 7
Nelson Tire pressure Spridgets 10
1 Tire pressure MG 8
AUSMHLY Correct tire pressure Austin Healey 8
bighealeysource tire pressure with radials Austin Healey 11
D tire pressure question Triumph 8
wkilleffer Good tire pressure for 18570R14 tires on a '74 'B? MG 19
bighealeysource Tire pressure Austin Healey 2
jlaird Tire pressure Spridgets 5
jlaird Lets get serious=tire pressure Spridgets 18
TRclassic3 Tire Pressure Triumph 9
J Tire air pressure Triumph 9
S Tire Pressure and Additives Jaguar 16
A Dumb tire pressure question MG 9
MadRiver Tire pressure? Triumph 8
vping Tire pressure MG 15
C TR2/3/3A TR3A Tire Pressure Triumph 6
Brosky Tire pressure question Triumph 24
P Correct Tire Pressure for 165R15... Austin Healey 2
J tire air pressure MG 6
S TR2/3/3A Tire balance Triumph 15
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
