Tie Rods and Ball Joints
KVH
I thought I'd repeat a question I posed in another post:
"When disassembling the front end of a TR4, how on earth can I disconnect the ball joints and tie rods without pounding with a pitch fork? I can't stand whacking the car with a hammer and pitch fork, and the modified "Churchill" tool I bought here in Town actually broke--the steel wasn't hard enough. thx
Alan_Myers
Hi,
I posted the following in response on the other thread...
Hi,
Go to jcwhitney.com and look up ZX881770B
Cheap. Works great on TR tie rod ends and ball joints. No whacking required. I've got a drawer full of other ball joint tools gathering dust. This one works. I don't know why it's designated for VW... it's universal.
Cheers!
Alan
Paul Johnson
Two hammers, careful aim and retracted thumbs. Simultaneously strike opposite sides. One good, sharp hit and the tie rod will fall out.
Banjo
Usually a few solid hits to the side of collar on the spindle where the pin of the joint goes through will pop it loose.
The compression force to the side of the tapered hole forces the tapered pin to back out (usually fairly quickly)
Don't be afraid to hit it.I haven't met a mechanic yet that dosen't own a BFH. (just watch your back swing)
As a matter of fact that's a common motto!
"when in doubt, get a bigger hammer"
I've never had a problem having to pound or drill on a car, no matter how nice. It's what's required for the repair. Today at work I get to drill BIG holes in the hatch of a new Scion TC with 2 miles on it to install a spoiler. Cool!
G
I agree with Alan, the tie rod/ball joint extractor tool is worth the 11 bucks. Moss has them as well. Guess that's why I set my points with a dwell meter, too. Never was any good at "tricks of the trade". There is a difference between knowing the tricks of the trade and knowing the trade. Seems I know neither. That's why I like tools.
Bill
martx-5
I agree with banjo and paul by using the hammer method. When I first got out of the Army in 1970, I was working in a repair shop and was struggling with a pickle fork to seperate a tie rod end. An old mechanic walked up with a hammer in hand, said "Excuse me, here's how it's done". He whacked the side of the joint once with the hammer and it seperated. My mouth dropped to the ground. So, in the all the years since, I've taken EVERY tapered joint apart using this method, and have never harmed any parts. A couple of hardy whacks with a BFH on the collar that encircles the tapered pin will seperate the joint. If you have the room, back up the opposite side from where you are striking with another hammer. The first time you use this method may seem a bit intimidating, but once that joint seperates so easily, you will never again go looking for that "special" tool. /ubbthreads/images/graemlins/cheers.gif
kodpkd Adjustable Tie Rods Austin Healey 20
B TR4/4A Outer tie rods Triumph 8
K TR2/3/3A New Tie rods and Ends Triumph 3
AH67AH Tie Rods / Alignment Austin Healey 3
R Tie rods zerk Austin Healey 32
T TR4/4A Question on inner tie-rods for TR4a Triumph 3
Basil EType Tie-rods Jaguar 2
M Steering Rack Inner Tie rods Spridgets 9
6 Whats the Proper Way to Remove Tie rods on AH BJ8? Austin Healey 17
T TR2/3/3A TR3 tie rods - made of precious metal or what? Triumph 6
Baz Quik Q on tie-rods Spridgets 28
tr6web TR6 Outer tie rods - TR6 Triumph 10
tr6web TR6 TR6 Steering rack - tie rods and more... Triumph 3
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
W Correct Tie Rod Ends Spridgets 0
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
K TR2/3/3A Removal of tie rod end? Triumph 7
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
R TR2/3/3A Tie Member for TR-2 Triumph 2
F TR2/3/3A Tie member[front apron support tube] Triumph 11
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
M Hauling a Spridget - Proper tie down technique? Spridgets 15
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Feathers 289I inner tie rod end. TVR 0
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
Bruce Bowker For Sale MG Tie Clip MG Classifieds 1
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
steveg Tie Rod boots - urethane Austin Healey 22
Patrick67BJ8 Tie Downs for a BJ8 Austin Healey 17
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
W Inner Tie Rod Spridgets 3
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
D TR6 Tie-rod problem Triumph 4
S What do you use instead of tie wraps? Austin Healey 7
jlaird Tie down Spridgets 0
jlaird Rear tie downs for old folks Spridgets 20
M Tie rod end came apart easy - too easy? Spridgets 6
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
DornTRoriginal TR2/3/3A Tie Rod Adjustment Triumph 6
Sopwith_Camel Tie rod ends Spridgets 12
P Tightening Tie Rod Ends? Spridgets 4
