The non-garage garage
NutmegCT
Bronze
Suggestions requested!
I have no space to legally build a real garage on my property; my "free space" is too close to adjacent property and septic leach field. But I sure hate to leave my old car (presently a Rambler) outdoors; New England rain, snow, dust, summer sun, and critters cause problems. I only have a gravel driveway and parking area; can't have a concrete slab or driveway, due to nearness of neighbor's septic leach field.
From experience, I know that "all weather car covers" don't protect much, and can lead to mold or even *more* critters inside, not to mention scratching the paint when putting on and taking off the cover.
I don't want to rent a garage (ca. $200/mo) over a mile away - even if I could find one. I've done that before, and working on the car is next to impossible.
So I'm considering single-car versions of carports like:
I'd have to keep the gravel parking surface I have now, but enclose the carport sides with solid walls (provided by manufacturer). It's really frustrating to see acid rain spots and bird droppings eating away at the paint - not to mention trying to work on the car with sun blinding me with glare.
Any thoughts?
Thanks.
Tom M.
you see a lot in Northern Ontario - as long as you don't expect a "real" garage, you should be fine - and, I expect you get what you pay for.
Might also be worth considering finding a place to store for the winter as you (we? as we get older) aren't likely to be crawling around outside anyways. I found a spot in a condo undergound parking lot (ABarth69's sister in law) for a great price. Ask around and you might find an empty garage.
You also should check zoning laws for temporary structures.
I do agree with JP.... Check around and you just might find a suitable space at a reasonable price.
Thanks J-P and Elliot. I've been looking for a local covered parking space for over five years. Nothing - believe me, nothing. Closest I found was a $600/month "small warehouse", on private property, in a "dubious" neighborhood.
I'm checking manufacturers for snow load, warranty, etc. Have to carefully balance the need and size, to what my free space and the local regulations permit. Every county has slightly different regs and definitions.
You should also inquire about UV inhibitors for the material. The ones that are not protected won't last long.
Just a thought : You might double-check the local codes to see if unoccupied structures still require the same set back from the leach field as a home does. Sometimes the rules are different (or even non-existent) for small out-buildings; especially if you can get away without pouring a footer. Usually there is a 10 foot setback requirement for the leach field to the property line, so even if you build to the line, you should still be 10' (minimum) from the field.
If you can clear that hurdle, it might be possible to get a variance for building a garage to the property line.
Check zoning for possible shed without a permanent structure base. We can erect sheds with plywood floor as long as not permanently affixed. I placed mine in concrete blocks buried in dirt and exposed about 2 inches above ground level. You could also use railroad ties as base. In our town as long as the structure can be moved it qualifies. Can not has to be movable.
Thanks gents. Fortunately the county *will* accept a non-floored structure right up to the septic leach field. However, the town won't accept *any* structure that's within 10 feet of another property line.
So my (admittedly last ditch and laughable) idea is to find a "carport" which will fit between my workshop and the leach field. Here's the area:
Needs to be relatively flush with workshop on left, but not block the doors, and extend only to the right where the gravel stops. Edge of gravel marks edge of septic field.
Green shed is lawn stuff. So there's about 20 feet left to right, and 20 feet from rear of Rambler to back of green shed. Carport can't extend any further toward where I'm standing, as the supports would interfere with parking the other car.
(Sometimes it seems there are way too many puzzle pieces to wrestle with ...)
By the way, see all that nice flat open space beyond the green shed? It's not my property ....
I cannot see how the town allowed a leach field so close to someone else's property.
Short version: the two properties were originally one piece, owned by one person. My house was built on that property in 1826 - the only house there. But the owner in 1972 decided to build a modern house, and rent the original old house. When she died, her family split the property into two properties and sold them separately, to two different people.
So the property line between the two properties came into being *after* the two leach fields were put in.
Nothing is simple ...
Another thought - is there someone near you,
that'd let you park a storage container on their property?
I can't add anything beyond the suggestions already given. But I like your Rambler. My grandson has a '60 Classic that he is slowly trying to rejuvenate.
More Rambler photos. Really runs well now, even the "Flash o matic" 3 speed automatic.
https://s224.photobucket.com/user/freemangarden/slideshow/1958 Rambler American?sort=6
When I was a kid, we had a 1952 Nash Rambler wagon. Then moved "up" to a 1956 Rambler Cross Country wagon, then a 1961 Rambler Classic wagon.
T.
Grandson's Rambler was bought new by my wife's grandfather and has been in the family ever since. So it has a lot of sentimental value too. Do you have any suggestions of parts sources for him?
tr6nitjulius General TR All TRIUMPH Drive In 7/26-28 2024 Vernon, B.C. Triumph 0
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
T TR6 Spinon Oil Filter Adapter Triumph 3
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
K Wanted A set of TR3A windshield tenon plates. Triumph Classifieds 1
Rut Interesting non Spridget Spridgets 3
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
N John Lennon Austin Healey Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
J Lots of numbers on the Crown and Pinon pumpkin! Austin Healey 3
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
Boggsy64 MGB Starter - Non starter? MG 16
