TR2/3/3A Resistor plugs vs. non-resistor plugs?
GTP1960
Any opinions out there on which class of plug is best for a 3A engine?
thanks for your input.
Guy
CJD
It all depends on whether you want anyone within a hundred yards to be able to hear their radio or not! I would recommend resistor plugs and wires.
TR3driver
Great Pumpkin - R.I.P
I ran the Bosch Platinums for many years, based on a comment from Ken G. that they found another 5 hp on the dyno with them on a race engine. Never could tell that they made any difference in my street engine, though.
But after I had an entire set of them fail, and Ken noted the same failure in one of their race cars; I switched back to the old Champion L87YC plugs. They don't last as long as the platinums, but they are readily available and cheap.
They are non-resistor plugs, but I've never noticed any particular ignition noise from them (I do have resistor plug caps and of course the distributor cap has a resistor in it) even in my own radio. Years ago, when I used a CB radio in a different 56 TR3, the main source of RF noise was the generator (and I added a filter cap on the output to cut down the noise).
GTP1960
GTP1960
Champion web site does have a resistor L87YC (RL87YC). & it is recommended for 1961 TR4's.
no mention of TR3.
Plug Type: RL87YC
Seat Type: Gasket
Hex Size (Inch): 0.813
Hex Size (MM): 20.65
Thread Size (Inch): 0.551
Thread Size (MM): 14
Thread Reach (Inch): 0.5
Taper Diameter (Inch): 0.31
Installed Height: 2.24
Insulator Projection (Inch): 0.06
Gap (Inch): 0.037-0.043
Gap (MM): 0.94-1.09
Center Electrode Diameter (Inch): 0.1
Center Electrode Material: Nickel Copper Alloy
Ground Electrode Material: Nickel Copper Alloy
Classification: Champion Copper Plus Small Engine
Resistor Plug: Y
FWIW: when cross referencing the original champion L10S( apparently no longer available), the recommended plug was an L82YC. It appears to be similar to the 87 but has a gap of:
Gap (Inch): 0.03-0.035
Gap (MM): 0.76-0.89
GTP1960
GTP1960
Well that explains it:
All this time I thought the interference I was getting from the cars next to me was Rapp music.
TR3driver
FWIW, the L82Y is the next colder Champion plug in the series, after L87Y.
Well, I don't recall how I got started using them, but L87Y is what I've been using. Maybe the hotter plug was to cut down on fouling.
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
Jim_Stevens TR2/3/3A Ballast resistor to prevent hyperflashing Triumph 5
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
NutmegCT ballast resistor Other Cars 10
A Ballast resistor Triumph 7
TulsaFred Ballast resistor Spridgets 28
regularman Ballast resistor mystery Spridgets 2
A ballast resistor 75 mgb FORUM Navigation Questions 0
A MGB ballast resistor 75 mgb MG 2
H Ballast resistor MG 9
RynoBoy74tr6 Ballast resistor location.... Triumph 10
19_again resistor MG 2
newmexTR3 TR2/3/3A Pertronix on TR3 Ballast Resistor or no? Triumph 3
J Tach resistor Spridgets 8
8 BALLAST RESISTOR???? Triumph 12
J Spitfire Spitfire Ballast Resistor Triumph 3
C Ballast Resistor Spridgets 34
B TR6 TR6 / Pertronix / Ballast Resistor / etc Triumph 13
RichC Primary Ballast Resistor Ignition? MG 1
H TR6 tr6 heater motor resistor Triumph 0
R Link to Ballast resistor wireing Jaguar 0
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
A MGB Welsh plugs MG 9
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
longbridgehealey NGK plugs Austin Healey 23
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
A Oil Galley Plugs Spridgets 0
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
tahoe healey Spark Plugs Austin Healey 20
I Weeping Core Plugs Austin Healey 6
G spark plugs Austin Healey 10
R General Tech Aluminum oil gallery plugs Triumph 3
S TR4/4A 1/2" blanking plugs Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
