TR6 Test starter system with engine out?
gbtr6
My six wouldn't start and I am going to trailer it home. I need to take the engine out to rebuild. My question is, since it wouldn't start, and the engine is out, can I still check the starting circuit?
Thanks,
Perry
TR3driver
Great Pumpkin - R.I.P
I'm not sure I understand which bit you want to test, but you should be able to come up with something. To check the starter and solenoid, sit the battery on the floor next to the engine and hook up the cables, then use a jumper to stimulate the solenoid. For the ignition switch and wiring, hook the battery up to the car and put some sort of dummy load (like an old headlight bulb) on the white/red wire that normally goes to the starter. Or, you can hook the starter up without having it mounted to the engine, by running a ground cable to the starter, and see if it spins.
TomMull
Randall has pretty much got it covered but there are a couple of things that might get fixed with the engine r & r that can't be checked with the engine out, e.g. the engine to body ground strap. All the connections should at least be cleaned as part of the rebuild and there's a good chance the start problem will go away. If it doesn't, it might be easier to diagnose with the engine back in. Same with the starter motor, new brushes at least if not a replacement or rebuild.
Tom
gbtr6
gbtr6
Well, I have the 6 home. I will clean the ground and check what I can. I'd like to get it to start then remove the engine. Lots of work, but I've been there before.
Perry
gbtr6
gbtr6
OK, I was fiddling with the harness on the back of the ignition as well as the seatbelt warning buzzer. I forgot to mention, I have a TR 4 ignition switch. After I jiggled these around, I have a click at the firewall, the relay I believe. So, I have juice that far. What next? I use jiggling as my technical term, so that shows how well I do with electrical diagnosos and repair.
Perry
poolboy
Having a 74 with a TR4 ignition switch, none of this may apply, but you'd want to verify that you have juice coming into the relay thru the brown wire and juice leaving the relay thru the white/red wire.
If so, then you want to see if that juice that left the relay in the white/red wire made it to the starter solenoid.
Is so, did the starter solenoid make any noise ?
One or two more steps after that and you should know what's wrong.
gbtr6
gbtr6
Thanks for the reply. How much voltage should I have at the brown wire coming in? How much going out? I have a multimeter so I can check that. If that checks out, do I check the small wire on the starter, or the larger red one?
Perry
poolboy
The brown wires should be the same voltage as the battery.
All insulated wires connected to a 74 starter and solenoid would be 12+ volts ...if you have a good battery.
Do you have a wiring schematic for your 74 ?
As far as I know the only wires carrying less than 12 volts would be the ballast resistor wire on the coil and the wires from the voltage stabilizer to the fuel and temperature gauges.,
But all the stuff you are fooling with are in the 12 volt category.
gbtr6
gbtr6
Good, thanks. I have the Haynes manual and the complete Triumph workshop manual so I think I have a schematic.
Perry
gbtr6
gbtr6
Thanks a lot for the schematics, I appreciate it. I can even read it and understand a bit. I'll get to testing this weekend.
gbtr6
gbtr6
Update. My son was home and I had him help take the hood off. Then, had him start it. At first only the click so I beat on the relay with my screwdriver and it started. It sounded horrible though, so I am glad it started and I know I need to get it rebuilt. On to taking it apart.
Perry
poolboy
When you discover what caused the zero compression in that cylinder, let us know and Good Luck !
gbtr6
gbtr6
Will do. When started it sounded horrible, like some lower end noise. I am a bit afraid, however am committed to a complete rebuild so it should be good.
gbtr6
gbtr6
Update. Finally made some progress. I've had a sore leg that has slower me down some. Work on it for about an hour and a half and Harv it ready to take the transmission out. Then the engine can come out. I want to get the head off while its in the car as well. image.jpgimage.jpg
Pill have a crack at again tomorrow and get the interior out.
Perry
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
KVH General TR Overdrive Pressure Test Triumph 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
T TR2/3/3A 4th Test drive Triumph 12
S TR4/4A How to test Overdrive out of the car Triumph 45
P TR6 Latest compression test Triumph 11
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
S TR2/3/3A Test an overdrive trans. Triumph 6
T TR6 TR6 compression test Triumph 12
D LSR test run Racing 2
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
C High test or regular gas? Jaguar 4
C How to test shocks? Austin Healey 7
M Compression test results Austin Healey 11
NutmegCT TR2/3/3A Sports Cars Illustrated TR3 road test Triumph 17
J MGB Smog test fail MG 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
Lukens TR2/3/3A Is there a subforum that I can send "test" posts? Triumph 3
NutmegCT General Tech Condenser test? Triumph 38
B test a wiper motor? Spridgets 13
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
G TR4/4A tr4a vacuum test Triumph 13
