Temperature gauge went goofy!!
Russ Austin
My wife and I went shopping for a new refrigerator, so we jumped into the 3 and went shopping. After 30 or so minutes the temperature gauge read 175 to 180 degrees and everything seemed fine. Stopped at a place to look at some refrigerators came out got in the car and drove away, about 5 minutes later I looked at the gauge and it read like 100 degrees and falling. Got home looked under the bonnet and checked everything, any idea’s would be appreciated.
G
I want to know how the heck you were gonna fit a new refrigerator into that 3.
Russ Austin
Russ Austin
It wasn't easy!!
TR3driver
Great Pumpkin - R.I.P
Sounds like the gauge itself picked that moment to fail. The original TR3 gauge is fully mechanical, so no electrical connections to cause problems. The downside is that the slightest leak will let the ether out, ruining the gauge.
As a double-check, touch the thermostat housing. If it's too hot to keep your hand on (as it should be), then the gauge itself is broken. Unfortunately, repair of a mechanical temp gauge is beyond the usual DIY skills, so you can either send yours off to be repaired at some place, or buy another one. Working originals tend to bring as much or even more than the price to have them repaired (about $150 last I heard); but aftermarket gauges that will fit are much less expensive. I paid about $25 for a Sun-Pro gauge (but saw the same gauge for $40 in a Western Auto yesterday).
dklawson
Depending on your comfort level... you can possibly repair the broken gauge yourself. I was directed to the link below and eventually borrowed a broken Smiths dual-gauge just to try the method. It does work. You have to have some minor fabrication skills, the ability to solder, and you need to be careful and quick in your work. The total investment in materials is about $20 assuming you already have basic repair tools (I have yet to meet an LBC owner that doesn't have SOME tools).
See:
https://www.ply33.com/Repair/tempgauge
martx-5
See:
I used this method last year when the subject of repairing capillary gauges came up. It does require the purchase of a good capillary gauge in order to harvest the bulb of ether and tube. I've seen them in Pep Boys for $16-$20. The trickiest part of the operation is the splice joining the two tubes. They will most likely be of different diameters. You want to have that piece ready before you start the actual surgery. Other then that, the procedure is pretty simple.
DNK
Was just at the Portland ABFM, and 1 of the vender's had something I hadn't seen before. It was a radiator cap with a built in thermometer on it. He claims they are very accurate,more than the gauge,he says. Comes in different radiator pressures for different cars. I asked about 7lbs. but he didn't think so. Isn't that what the early 6's came with??
dklawson
That cap is a wonderful idea. Did they happen to mention how much they cost?
DNK
I got the picture of the jeggs site. Didn't even look at the price
TR3driver
Similar devices were popular back 70-90 years ago, when the radiator cap could be seen from the driver's seat. But now, why would you even open the hood/bonnet if you didn't already know there was a problem ?
And the gauge itself might be more accurate ... but if your problem is a stuck thermostat (or a broken fan belt or ...), it can still read cold even with the engine boiling.
Russ Austin
Russ Austin
Called Nisonger's this morning and was quoted $120. for a complete rebuild of the Temperature gauge. That's a lot better than the one on ebay at $162. and climbing. I had an extra gauge and will have sent that one. Doing it myself I thought was a little beyond me.
TexasKnucklehead
I'm not overly concerned with originality, when it comes to stuff like this. I have a temperature gauge from an early TR4, with a curved face, full-length needle, and very similar font to the TR3 gauge. Since I needed a full set of gauges anyway, I opted for a TR4 set because I didn't want to mess with the tube-type temperature gauge. I have a new sending unit (that fits into the same hole as the cap-tube unit) and will have to add a wire, and voltage stabilizer. I think most people will never notice how un-original it is. I'm thinking this will allow my gauge to be functional at a fraction of the cost.
TR3driver
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Just a thought, though, you might want to check the calibration before you install it. Not a requirement of course, but lots of people (including me) have had issues with the electric temp gauges being off.
A pan of water (or oil if you want to go over 212F) and a candy thermometer on the kitchen stove is one way to check it. Be sure to let it stabilize for several minutes at each temperature, since the electric gauges are remarkably slow to respond. Several times now, I've seen the steam _before_ the needle gets to the red /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
toysrrus
Hey Russ;
I would post that pic on the Calender Contest! That one is really neat!!
Regards, Russ /bcforum/images/%%GRAEMLIN_URL%%/winner1.gif
T
Tinster
Russ,
When we got our TR6 the temp gauge ran at the very
bottom end, hardly moved at all. DPO Pedro said that
was because British cars usually run very cool because
of their large radiators.
I found out different, of course. I tried about everything
mentioned, even cooking it. I bought 2 new temp senders, a
new voltage regulator, a new sending wire and a new ground
wire. Nothing worked. gauge ran at the bottom.
I refuse to pay the highway robbery price for a reconditioned
Smith. I purchased a $70. aftermarket gauge, took it apart
and painted it to match my other gauges. Used my IR gun
and the new gauge is quite accurate.
I am happy with the aftermarket gauge.
d
TexasKnucklehead
The TR6 temp gauge is nothing compared to the TR3 one. A rebuilt one just sold on ebay for $286 (pig not included).
https://offer.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewBids&item=270159582328
Next time you need something like that, let me know. I know a guy here in Houston that has lots of TR6 stuff. He sold me a TR6 transmission for $20 -that was taken apart, but complete. I only needed the counter shaft/1st/rev assy, but took the whole lot.
Russ Austin
Russ Austin
Received my Temperature gauge back from Nisonger's (very quick turn around) in one week. They quoted me $120. and that's what they charge me. Couldn't be happier!!! it looks brand new and the one on ebay sold for over $220.
BierRunner TR6 Temperature Gauge Triumph 8
R Coolant temperature gauge Spridgets 8
B TR2/3/3A TR3 Temperature gauge Triumph 19
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Russ Austin Temperature gauge bulb stuck in thermost houseing! Triumph 10
L TR2/3/3A TR3A - measuring operating temperature w/o gauge? Triumph 12
K Smiths Electric Temperature Gauge Triumph 7
Tinkerman TR2/3/3A TR3A Temperature gauge capilliary tube routing. Triumph 0
W TR2/3/3A Temperature Gauge Rebuild TR3 Triumph 19
MGTF1250Dave TR2/3/3A TR3 Temperature Gauge Face Markings Triumph 3
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
RandallRK Temperature Gauge reading Austin Healey 2
regularman Temperature gauge Spridgets 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
H TR2/3/3A TR3 Temperature gauge Triumph 23
Brooklands TR2/3/3A TR3 Temperature Gauge Triumph 38
T TR2/3/3A Trouble shooting TR3a Temperature gauge Triumph 13
TR4 Temperature Gauge Issue Triumph 8
C Temperature Gauge MG 23
D TR4/4A tr4 temperature gauge/sensor reading Triumph 11
fmichaels temperature gauge question Spridgets 6
Trevor Jessie Driving without temperature gauge Spridgets 8
W Temperature Gauge calibration Triumph 4
Dugger Temperature gauge Triumph 4
R "wonkey" Temperature Gauge Austin Healey 6
S TR2/3/3A Tr3 temperature gauge route Triumph 12
Webb Sledge TR6 TR6 Temperature Gauge Triumph 19
G New member with temperature gauge question MG 5
MGTF1250Dave Water Temperature Gauge Triumph 2
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
