Tachometer thrust button
Steve Huneck
Member
Hi,
The mechanical tach on my BJ7 is missing the pinion thrust button. The tach has always worked until recently, so I'm not sure what happened to it. Anyway, Moss Motors does not have the part so I am wondering if anyone has any ideas on an alternative.
Thanks,
Steve
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
