TR6 suggestions for brake LED bulbs
ichthos
Anyone have a suggestion for an LED bulb for the brake light? One reason I would like to switch is it looks like the plastic reflector has melted partially around the reflector in both tail lights. Bought one for another car, but wasn't happy with it. Any help/suggestions are appreciated.
TR3driver
Great Pumpkin - R.I.P
That discussion appears to be for a TR3, which is something of a special case. I don't believe a TR6 has the same issues.
The big problem with a TR3 is that LEDs are always more-or-less directional, and the tail/brake lights (or tail/turn on early cars like mine) mount the bulb at a funny angle. But a TR6 mounts the bulb in the conventional orientation, so that is much less of an issue.
Litezupp https://www.litezupp.com/ has a good reputation and is sensitive to the needs of vintage car owners. They actually offer a bulb that is customized for the TR3 corner lamps!
Personally, I wanted more light, so I've been working on rolling my own. I also added a flasher circuit to the center brake light, so it quickly pulses about 5 times when I hit the brakes. The corner light is so bright that my wife literally said there was something wrong with the other side, it was too dim :smile:
Brake lights should be no problem, but if you use LEDs for turn signals there will be some other changes required. Different turn and hazard flashers, plus probably some dummy resistors to get the indicator on the dash to work properly.
mgedit
Thanks for the clarification Randell. I wrongly though the question was about TR3 lights. I am going to experiment with LEDs in my TR6. Switched to LEDs in dash and very happy. Are you neg ground with your TR3 to make the flasher module work on the centre light, or did you design your own? I bought a flasher module on ebay some time ago to use with a third brake light I want to add to my TR6 but it is neg ground only. Having that centre light flash would be nice on the 3. I seem to recall you have all three rear lights working as brake light too. Cheers, Mike
TR3driver
I am negative ground; but the flasher is my own design and I could have just as easily made it positive ground (I think). My goal was to have everything fit inside the lens, so there wouldn't be room for a module anyway. The flasher is just a NE556 dual timer IC with some associated resistors and capacitors so that one timer section does the quick flashes, and the other timer section disables the first after about 5 flashes. Then the output controls a power MOSFET (from the junk box) which in turn controls the LEDs.
Another change from stock, the red LEDs are mounted to an aluminum plate that divides the lens front/rear. That way, the license light (white LEDs) does not show red to the rear.
I do also have the corner lights working as both stop and turn. That was done earlier, with relays mounted under the dash, so I just left it intact (except for adding a resistor across the center brake light).
This isn't a very good photo, as you can't really see the differences in brightness, but I was trying to compare the LED center light to the wife's Toyota. I need to find a way to override the automatic shutter speed on my camera (should be much easier on the new camera, but I haven't tried it yet).
mgedit
Thanks Randall. Sorting out how to make the flasher is beyond my electrical capabilities. The three brake light setup is very nice. I have some diagrams of how others have done that, and may try to sort that out one day. Cheers, Mike
I
ichthos
Thanks for all the suggestions. I will check out the leads listed. Poolboy did you order the red led lights? Also, when you said reconditioned reflectors, did you restore them yourself? I sprayed mine with a silver chrome paint after splicing/repairing one of the reflectors. I switched to LEDs for my dash and am very happy with the better visibility at night.
poolboy
Yes, you should have a red LED's behind a red lens.
I tried the chrome paint, but later I used a mylar food storage bag, cut it to shape and glued it to the reflector.
It seemed to be a bit brighter.
martx-5
... The flasher is just a NE566 chip with some associated resistors and capacitors so that one timer section does the quick flashes, and the other timer section disables the first after about 5 flashes. Then the output controls a power MOSFET (from the junk box) which in turn controls the LEDs...
I assume you mean a 556 dual timer IC. Great idea. I just might do this myself.
TR3driver
Good catch! Thanks, Art.
I updated the post to hopefully reduce future confusion.
M suggestions on vendor Rear brake rebuild Spridgets 15
TRMark Brake pad suggestions Triumph 16
M suggestions for brake system Spridgets 9
J rear brake rubbing, need suggestions Triumph 12
Steve P. master brake/clutch re-sleeve...suggestions Spridgets 3
I Bugeye valve rebuild suggestions Spridgets 8
D Shop lighting suggestions. Restoration & Tools 8
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
catfood Looking for suggestions - ignition issue Austin Healey 6
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
I General TR Mold clean up suggestions Triumph 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
DerekJ Healey Blue Paint - suggestions Austin Healey 23
J General TR D Type overdrive not working need suggestions Triumph 5
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
I TR6 Muffler suggestions? Triumph 6
HealeyDave Car transport company suggestions needed - winter/midwest/USA Austin Healey 2
M Overdrive parts source suggestions Austin Healey 4
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
S TR6 Suggestions: cylinder head won't release from block Triumph 10
Zimmycobra Trans problem. Looking for suggestions. Triumph 10
S Any suggestions on where to start? MG 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
I Suggestions for bugeye headlights Spridgets 21
RAC68 Paint & Design Suggestions Triumph 4
Andrew Mace lacquer primer removal suggestions Triumph 4
I LED tail light suggestions? Spridgets 22
G TR6 Radio suggestions for fitting to TR6 Triumph 3
hondo402000 suggestions on Ignition coils Triumph 22
I Suggestions for tach gear rebuild? Spridgets 8
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
I Adhesive suggestions? Spridgets 4
I Wax, rubbing compound suggestions Spridgets 10
AngliaGT Subaru Wagon Suggestions? Other Cars 8
I Suggestions for new Bugeye soft top? Spridgets 3
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
RAC68 Suggestions – LED Project Austin Healey 24
O Suggestions.. Austin Healey 8
