RAC68
Hi All,
My present objective is to reduce the amperage passing through the 47-year old flasher relay box. My initial thought is to install 1157 (BA15D) replacement LEDs. However, there are some issues to address.
1. Does anyone have an LED recommendation, with superior brightness, for a replacement 1157 incandescent bulbs?
2. It seems that, due to the low LED amperage draw, the original flasher will not work. Published resolutions include the installation of an electronic flasher or resistors placed across each bulb. Does anyone have any ideas on whether a single resistor, attached to the line wire at the flasher, would satisfy this issue? If appropriate, what resistor value would work?
3. An alternative to LED-installation could be the application of 2 relays to offload the rear brake and directional load. I would appreciate any thoughts on this approach as the rear lights represents the major electrical current passing through the flasher box.
Thanks and all the best,
Ray (64BJ8P1)
Ray (64BJ8P1)
