I saw a picture of a TR3 engine bay where the owner had replaced the U shaped gas line connector under the SU's with a braided steel hose connector that ran over top the float float bowls. This hose then connects to the steel gas line at about the rad cap area.An L shaped bracket with a rubber grommet is fastened to an upper thermostat housing bolt to keep it steady. The line then continues in the usual way to the pump. Anyone know who supplies the "Braided Steel Hose Bling"?
