Stupid question
mbillips
I am trying to remove the head from my 1986 Series III Vanden Plas, and the shop manuals all blithely say to turn the crankshaft in order to line up the camshaft bolts, without saying exactly HOW to turn the crankshaft. I'm not sure which direction to go with it, and everything is so crowded that I can't get a wrench on the crank. Also, my biggest socket is 1 1/4 inch, which is too small. Should I remove the belts, or some of them? I can get a little movement by pulling on the power steering pump belt, but not enough to actually turn the crankshaft. I've removed the spark plugs, so engine compression shouldn't be in the way.
Can anyone tell me the exact size sprocket and which way to turn, or any useful tips on an easier way to turn the crankshaft? Being baffled by such a simple step is highly frustrating. Thanks.
If it doesn't have to be exact.. you can bump it with the starter. That should get you approx where you need to be.. Then you may be able to turn it over with a wrench on the generator..
[ 04-23-2003: Message edited by: TypeRboy ]</p>
If the engine is at tdc, spin it over and do those bolts first, then turn again back to tdc and do the last ones. (in case you have your engine at tdc when you start, it will be when you put the head back on, or else the cams are 180 out)
I think its 1 3/16, just check that the store is cool with you returning wrong sizes before you buy it.
I turn it over from underneath, I think I use the socket, and a 1" wobble extention on the ratchet.
If you haven't already, pulling the plugs should make the engine spin quite easily by any accessory pulley.
L TR2/3/3A Stupid Engine cleaning question Triumph 9
C windshield wiper stupid question Spridgets 7
C stupid question on tranny oil Spridgets 9
bugedd Stupid question Spridgets 3
mailbox Stupid question Restoration & Tools 6
J Possibly stupid question about drivetrain / rear end Spridgets 11
jlaird Another stupid question from your old friend Spridgets 18
DNK Stupid Question Time Triumph 12
livinginthepast This may seem like a stupid oil change question... Spridgets 5
jackq Stupid 1622 eng. question MG 3
thechileman TR4/4A TR4 Stupid question Triumph 11
B Stupid Question..flat tire issue Spridgets 3
I TR6 69 TR6 - Another stupid wheel question Triumph 8
T Another stupid question Triumph 13
T Another stupid question Triumph 14
T Tinster Stupid Question No. 783 Triumph 24
T Today's Second Stupid Question? Triumph 8
T Today's Stupid Question Triumph 32
T Another stupid question Triumph 42
DNK Real Stupid Question Triumph 2
NutmegCT Stupid tire/wheel question. Triumph 18
J stupid question of the day - dipping the tub Triumph 4
R Stupid question #1 - steering wheel Spridgets 23
Jayrz Now for my next stupid Question, Distributor Spridgets 4
K MGB First stupid question. rear deck hardware 71 mgb MG 17
weewillie a stupid question Spridgets 13
Thomas591 Stupid question on 100 BN2 Axle Austin Healey 3
jlaird Something stupid from Haynes and a question. Spridgets 17
DNK Stupid Question Triumph 13
C Charging system-stupid newbie question Spridgets 63
spiny Hello, possible stupid question .... crank pulley Spridgets 21
C Stupid Newbie Question Spridgets 4
Andy Blackley Stupid Ignitor Question Triumph 10
IanF Stupid drum brake question... Triumph 14
H Quick stupid question about shift knobs Triumph 2
JPSmit Stupid Compressor Question Restoration & Tools 9
T Post-War Other some stupid question triumph herald, help!!! Triumph 15
MattP Ok, Stupid question time. MG 6
martyc Help! Stupid Half-Tonneau Question MG 3
Y Stupid Question Alert: Using a Jack on the Healey Austin Healey 4
J sorry for this stupid question MG 9
7 stupid plastic cooling system parts Other Cars 2
Rut Stupid is as stupid does... Spridgets 13
AngliaGT This Must Be STUPID Week Spotted 4
M I'm computer stupid! can't load pictures MG 18
tri_carb_healey i did something stupid Austin Healey 13
beachbumbarry I hate to admit that I'm Stupid MG 3
D i made a stupid mistake. best course of action? Triumph 35
waltesefalcon I may be stupid. Triumph 14
glemon stupid human tricks mechanical advance Triumph 25
