Stupid 1622 eng. question
jackq
A while back I bought an engine for my A coupe. When it arrived I gave it a quick once-over and shelved it. Then I started checking it over closer and its stamped 1622 on the side but the riveted on eng. number tag is unreadable. Any ideas?? Plus I probaly won't use the thing now as I'm going with a B 1800 with o/d. Its complete and clean and I may be able to fire it up, or at least do a complete comp. check.
bob67bgt
If it has a tach drive its a MGA Mk2. Also the head(originally) will have a "16" cast into it at the back. Non MGA 1622's had a "15" cast head and no tach drive unless its from something like a Riley. There were some later 1622's with no tach drive that used a 5 main oil pump from what i recall. MGA mk2 engine numbers started with 16GC. Bob
billspohn
There were never any 1622s that used a 5 main oil pump - very different parts.
There were no 1622s installed in Rileys. The only other uses I can think about that would have had a tach drive were Elva and TVR. The Austin A60 Cambridge was a good source of spares for the 1622 - you could even drill out the hole for the tach drive and (as long as you used a cam with the tach gear on it) run a tach off it.
The '16' and '18' heads are identical except for that number cast on them - both have the same chamber volume and valve sizes.
jackq
jackq
Appreciate the info. I just want to post the correct info when I finally list all this stuff on evilbay....
L TR2/3/3A Stupid Engine cleaning question Triumph 9
C windshield wiper stupid question Spridgets 7
7 stupid plastic cooling system parts Other Cars 2
C stupid question on tranny oil Spridgets 9
Rut Stupid is as stupid does... Spridgets 13
bugedd Stupid question Spridgets 3
mailbox Stupid question Restoration & Tools 6
J Possibly stupid question about drivetrain / rear end Spridgets 11
AngliaGT This Must Be STUPID Week Spotted 4
M I'm computer stupid! can't load pictures MG 18
jlaird Another stupid question from your old friend Spridgets 18
DNK Stupid Question Time Triumph 12
tri_carb_healey i did something stupid Austin Healey 13
beachbumbarry I hate to admit that I'm Stupid MG 3
D i made a stupid mistake. best course of action? Triumph 35
waltesefalcon I may be stupid. Triumph 14
glemon stupid human tricks mechanical advance Triumph 25
G Broke the stupid heater pipe Spridgets 5
G OK I guess I'm just stupid! MG 4
livinginthepast This may seem like a stupid oil change question... Spridgets 5
thechileman TR4/4A TR4 Stupid question Triumph 11
livinginthepast Stupid Q dejour | After Market Gauges Spridgets 5
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
Stewart Stupid stupid stupid MG 0
B Stupid Question..flat tire issue Spridgets 3
T Once more for the stupid guy? Triumph 12
I TR6 69 TR6 - Another stupid wheel question Triumph 8
Morris Stupid project idea... Spridgets 9
T Another stupid question Triumph 13
T Another stupid question Triumph 14
T Tinster Stupid Question No. 783 Triumph 24
JPSmit Before I do something stupid Spridgets 29
T Stupid Questioned Answered Triumph 21
T Today's Second Stupid Question? Triumph 8
T Today's Stupid Question Triumph 32
T Another stupid question Triumph 42
DNK Real Stupid Question Triumph 2
NutmegCT Stupid tire/wheel question. Triumph 18
J stupid question of the day - dipping the tub Triumph 4
R Stupid question #1 - steering wheel Spridgets 23
Jayrz Now for my next stupid Question, Distributor Spridgets 4
K MGB First stupid question. rear deck hardware 71 mgb MG 17
T Please pardon another stupid ?? Triumph 2
19_again is this really stupid? MG 21
toysrrus TR4/4A `67 TR4A-IRS on ebay for $4600 / Scam or Stupid? Triumph 47
weewillie a stupid question Spridgets 13
Thomas591 Stupid question on 100 BN2 Axle Austin Healey 3
Bret Shazbot! Did a stupid thing..... MG 9
drooartz Feeling stupid -- converting tachs Spridgets 11
jlaird Something stupid from Haynes and a question. Spridgets 17
