Stretching the V12
AussieV12
Now that it's looking a bit more possible for the V12 conversion, I've decided that 5.3 litres just isn't big enough. So for a few more questions:
What is the stroke of a stock 5.3 litre V12?
What is the size of the rod journel on the crank?
How long are the rods?
One website claimed they can be bored to 98 MM, true or false?
If true, could they be bored/sleeved to 4.000" ( Chev 350 size ) ?
linmalki
Stroke is 2.7559"
Rod journal is 2,2994-2.300"
stock bore is 3.543; one major piston manufacturer (AE/Hepolite) does not supply pistons in oversize; one is expected to replace sleeves rather than overbore. The outside diameter of the stock sleeve is 3.8585, so the sleeve can't be bored much if at all.
Sorry, couldn't find rod length.
The latest version (94-97) of the V12 is 6.0 litres, but it is also 3.543" so obviously it was stroked rather than bored. Don't have many specs on this engine, sorry.
A
AussieV12
The V12 has replaceable sleeves? Didn't know that. Anyway, some information is better than none. Hopefully another member can provide answers to the other questions.
A new question would have to be, what is the stroke of the 6.0 litre V12? And does it have the same rod journel dimensions?
A
AussieV12
Re:
Thanks for the link, but I couldn't find any info on what bore or stroke he used, or how he achieved it. I'm sure something will be posted sooner or later.
A stretching tonneau Triumph 10
Nelson Fitting [stretching] new soft top Spridgets 6
T Stretching a Tonneau ??? Triumph 10
AngliaGT Interesting Article on the V12 Jaguar 0
P For Sale v12 carbs Jaguar Classifieds 0
T 1993 xj v12 red hot catalytic converter Jaguar 6
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
CJD Valve shims on V12 Jaguar 19
P E Type V12 PCV & Smog systems Jaguar 8
V IRS selling a '73 XKE V12 Roadster Jaguar 0
B Looking for a Jaguar E-Type S3 V12 - LHD A/C unit Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
E 1990 XJ-S V12 Front Brake Locking Jaguar 5
Tullamore V12 E-Type Valve Covers Jaguar 10
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
Tullamore Custom V12 E-Type Project Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Tullamore Zapped V12 E-type Jaguar 9
W new shocks for jag xjs v12 ? Jaguar 3
Rick60 E-Type Series 3 V12 distributor Jaguar 5
Wray XJS Coupe V12 Jaguar 11
PAUL161 So You Want A V8? How About A V12 MG 5
J V12 Marelli Ignition Jaguar 12
D v12 top hoses??? Jaguar 4
D xjs v12 tire wear Jaguar 1
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
A V12 block cast date * 1st post * Jaguar 6
Sherlock Jaguar V12/1932 Ford Hotrod... Other British Cars 5
D 1991 xjs v12 strange pipe Jaguar 1
D grinding noise on 91 xjs v12 Jaguar 5
D 1991 xjs v12 high idle speed. Jaguar 8
D 1991 xjs v12 ,smell of fuel. Jaguar 4
G Looking at a 1988 XJ-S V12... CARFAX anyone? Jaguar 1
T Erratic idling v12 xjs Jaguar 2
Sergio MGA MGA 60 ROADSTER WITH BIG HEART JAG XJS V12 MG 6
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
D Modifying the Jag V12 engine. Jaguar 3
J 86 XJS v12 fuel pump problem -Help! Jaguar 9
B Fuel leakage at carby on V12 Jaguar 4
K V12 Engine Fires Jaguar 8
J Spotted a V12 yellow XKE coupe yesterday at gas station in NJ. and thought maybe??? Jaguar 2
Rick O. V12 E-Type; Should I? Jaguar 6
L Upgrades for a V12 Jaguar 1
J V12 Door on 68 E-Type OTS Jaguar 7
M XJS V12 Cruise Control Jaguar 3
M V12 Jaguar 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
R XJS V12 Problem Jaguar 5
