Still looking for various parts.
BWillis
Anyone out there have good used versions of the following that you would part with? If not I'll be forced to replace with aftermarket items.
Bumperettes w/brackets
Hubcaps
Grille
All for a bug of course. Also do any of you have a good source for a replacment wiring harness?
Ben in SC
Have seen all of the above on eBay reciently,
Grille $ 280 new rechrome, orginal items
Bumperettes $160 new rechrome, orginal items brackets for these Moss has or maybe it is VB.
Hubcaps forget what they were but not expensive to rechrome.
Wiring harness from BCF supporter https://www.britishwiring.com. Used one of their harnesses when I redid the Tunebug wires this past spring. Highly recommended.
Drew got it. Of course cheeper ones around but this is not a good place to save.
I replace the entire harness, which on the Bugeye is the main harness, headlight pigtails, and headlight dip switch harness. I used the PVC wires with cloth harness wrap. Looks pretty original, but has modern wires inside. You can get a pure stock harness, or a cheaper all modern one. I'm very happy with what I got, it all lined up and looks like it belongs.
The folks were very helpful, and also steered me towards the other little oddments and tools I would need (bullet ends, crimping tools, etc). When you're ready, give them a call and they'll take good care of you.
I think it was about $400 with the harness, tools, and a few connectors.
Ben, I've installed 4 or 5 of their harnesses, and can't say enough good things about them. Ed and Lesley are super people to deal with.
If you want the original look, they can supply modern wiring in the harness, with each wire dressed with the original style cloth overbraid.
Nice stuff, all of it.
Jeff
jlaird I am still looking Spridgets 17
R Still Looking Austin Healey 5
Tinkerman Still Looking for the correct fly wheel ring bolts Triumph 14
Nelson Warranty still good Spridgets 3
B Does anyone still make or sell a quality condenser? Austin Healey 14
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
sparkydave Odd discovery, but still ran OK Spridgets 1
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
RAC68 Directionals, Still a Pain Austin Healey 25
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
steveg Steering rebuild followup - still issues Austin Healey 29
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
K For Sale TR3 grille....not perfect but still useable. Triumph Classifieds 2
C elusive amswersHi Mine is a 66 BJ8. I have 2 questions that up till now I still canno Austin Healey 2
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
GTP1960 General Tech Still in business? Triumph 3
KVH General Tech Still on the Body Work Triumph 6
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
KVH General TR Still Losing Oil Triumph 5
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
BJ8Healeys The scammers are still at it Austin Healey 3
I Quantum Mechanics Ltd still in business? Spridgets 7
CZ_Dave MGB I'm still around MG 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
M Backfiring through carbs still Austin Healey 17
wangdango This BN2 still around? Austin Healey 6
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
R And Still Cooler in Florida Austin Healey 3
mgedit TR2/3/3A Still Overheating ... Triumph 22
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
bigbadbluetr6 TR6 TR-6 still not running right Triumph 31
G MGB STILL working on clutch slave MG 37
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
rjc157 I Donald were still alive Austin Healey 15
RAC68 Still being Surprised Austin Healey 7
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
P T-Series Does my Mark II TD still exist? MG 3
mrv8q They're still out there..... Austin Healey 26
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
KVH TR4/4A TR4A--still won't start Triumph 16
G MGB Still working on front suspesion MG 9
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
dougie Still Time for Christmas Austin Healey 2
