I was in the process of rebuilding front suspension on 74 gt
I pulled small cover off end of steering rack to check bearing play, very little gear lube came out. How much do I put back in,if you fill it wouldnt it run out to boots past bushings? /ubbthreads/images/graemlins/confused.gif
