spring is finally here
thegoodbeamer
Spring is finally here in the great white north.
The 62 is growling and pulling at me to let it out.The Lister started quite easily after being in hibernation for 5 months.
The 62 went under scrutiny this winter to make sure it would pass any inspection.This is because our goverment insurance crack down.Too many street racing deaths.They will even pull a car out of a show so we are ready.
After doing all the small minor things I decided to back the car out into the sunshine.as per usual it started up instantly.Well much to my surprise after it warmed up it would not turn off.Pullled a wire off the ballast.determined it was circulating power back through the igniter wire.After all these years I determined there was not enough resistance.The cure was to wire a bulb in the line.Problem solved.Now i need to check out the Lister as the alternator is wired exactly the same as the 62.
Oh yes on Monday we get the 62 licensed and let it out to do its stuff on a run with our club
aeronca65t
Good deal, Chuck!
I put the snow blower in my shed in "the back forty", so I sure hope the white stuff is gone. I've had the MGB out a half dozen times (all top down), but it's not super warm here yet.
EricG
Good to hear that your Sunbeams are out on the road again Chuck. Our spring started a few months ago and it has been great for top down driving. Pretty soon it will be way too hot though......! Eric
MikeP
I have yet to get anything of mind out, seems like whenever I have time lately it'l raining. Nearly a foot so far this month...
T
thegoodbeamer
Well we took the 62 out for a nice drive to have lunch.The destination is about 20 miles from home where met up with club members
I forgot over the winter just how great this car runs.Like a content cat it just purrs so nice it even impresses my wife.
At 65 MPH the motor is turning 1500 to 1550 RPM in 5 th gear
Nicer weather tomorrow so we will see how much time there will be left after everything is done that must be done tomorrow
T
thegoodbeamer
It really must be spring
I took the 62 yesterday to pick up parts..When I left it was sunny and clear.Got to town and it rained on me but the top was up so no harm done
Sure glad my car is a driver
T
thegoodbeamer
HOHO
Did I say spring was here
We got a real nice winter storm over the weekend.Highways were closed but still people will drive.5 people killed on the highways
At least it is sunny again and warming up
mgedit General TR Finally a Sniff of Spring Triumph 3
S TR2/3/3A tr3 valve spring compressor Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
Lotus Club SoCal LCoSC - Spring San Gabriel Mountains Drive Lotus 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
