Ed_K
On my 65 BJ8, I have the two front splash panels as seen as item # 10 on the Moss cataloge page;
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28952&SortOrder=17
They are flopping around a bit and there is a hole in the bottom front side of each panel. What does the stay look like ? I don't seem to have them but I need to do something to pull these splash gaurds toward the inside of the car and hold them in place. I made some out of threaded battery hold down rods and u shaped metal brackets that I bolted into the holes and the bent ends of the rods went into the holes on the upper panel cross brace, item # 7 . The problem is that my home made supports are too close to the grill opening and I don't seem to have enough room to install the grille. Item #15 is for BN7 and BT7, not BJ8.
What do the supports look like for a BJ8 and where do they go ?
...Which side of the grille goes up, the black painted side or the metal side ? What is the trick to install the grille, surround and the grille hood on the outside of the shroud ,(items 66, 69, and 60) on; https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28958&SortOrder=47
Any help will be appreciated. Thanks.
