Size or matching screw on cap for Trafalgar bottle?
Chet Zerlin
Hello all,
I've acquired a Trafalgar bottle and am now searching for an appropriately fitting screw on cap. Would anyone have either the dimensions needed or a source for a replacement cap?
Thanks!
Chet
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
B TR4/4A Oversize valves Triumph 3
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
C Chassis plate screwsize Austin Healey 6
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR2/3/3A Pixel primmer size Triumph 18
F TR2/3/3A Spare Tire Size Triumph 11
C Size of axle bearing nut Austin Healey 11
GeorgeC Steering wheel nut size? Spridgets 3
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A Belt Size for TR4A Triumph 4
P TR2/3/3A Recomended enclosed car hauler size? Triumph 8
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
George Zeck Wheel Stud Size? Spridgets 10
Jim_Gruber Size Matters Spridgets 3
2billydavies TR2/3/3A belt size for TR3a? Triumph 13
