Silentblok Bushings
jkaidor
Hello,
Last week, I noticed that our '55 TR2's handling had gotten even worse than usual, arriving at a level below what I would consider "safe".
So this weekend, I dug out an unused front suspension rebuild kit and went out to the car
to change out all the bushings ( yet again! ).
The obvious problem was not in the suspension itself, but in the steering linkage. The "Silentblok" that connects the steering box arm to the linkage was totally perished. The
other one - at the idler arm - was OK, but the idler arm itself had a bit of up & down play.
So I ordered a pair of new Silentbloks, a new idler arm, and a new idler arm socket from Moss.
It's not the first time that silentblok has failed: British rubber, lots of oil, grease, Blech!
Does anybody know of an uprated or upgraded part to replace the silentblok bushings? I guess they DO have to be rubber - I remember reading someplace that the front wheels have zero caster, so the tension in the rubber is the only thing making the steering self-centering.
- Jerry Kaidor ( jerry@tr2.com )
aeronca65t
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
KVH General Tech HS6 Carburetor Bushings Triumph 10
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
R TR6 Lower A-arm trunnion bushings Triumph 18
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
D TR2/3/3A steering column bushings Triumph 8
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
S TR6 steering column bushings Triumph 5
N Top link offset bushings?? Spridgets 6
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
B TR2/3/3A Inner wishbone bushings Triumph 5
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
M XK140 Sway Bar Bushings Slipping out of Brackets Jaguar 1
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
S King Pin Bushings Austin Healey 1
K TR2/3/3A Silent bloc bushings in the drag link. Triumph 2
C TR4/4A TR4A Differential Mounting Bushings Triumph 6
MY66AH Kingpin Bushings Spridgets 27
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
sim Fitting Damper bushings Question Spridgets 5
