TR2/3/3A Seat Installation
Redoakboo
I am finishing the restoration of a 54 TR-2 Long Door. I have installed the seat rails and am beginning to install the seats. Before I add the seats, the top rails slide back and forth with little effort. After I screw the seats down to the rails, I can not move the seats ? They won't go backwards or forwards. I can't seem to discover where they are binding? Would putting some extra washers on top of the sliding rail raise the seat high enough so it will not bind?
Any helpful suggestions??
Dick Vinal
You must use a ruler to install the floor rails perfectly parallel to each other. There is enough slop in the bolt holes to allow the rails to be installed off from each other, and then they bind when trying to slide.
Yes they are a pain. I leave the seat rails a little lose for a while, snug but not too tight. Then, I move seat back and forth for some time letting them find a comfortable parallel position and snug them slowly. Drive it around and move the seat with your weight on it. IMHO they do not have to be super tight. The seats are a weak point on these cars and the back of the seat will sage down below the rail and catch on the rail also. Perhaps something needs to be put on the back floor if you have the seat back all the way and the carpet in place.
steve
I had the same problem with my 56 TR3. I solved by adding a 1/4" steel spacer (short piece of tubing) under the seat rails. I put a small fender washer on top of the carpet, spacer on top of that, then the seat rail, bolt down trough the floor to a cage nut or large fender washer and lock nut. With three bolts per rail, they don't wiggle around and both seats slide back and forth the length of the rails. I got the spacers in the "Hillman" fastener drawers at Lowes.
Good luck!
Long Boat on the way---Vikings never surrender--- Not all Seattle is like what you see on TV—hope emergency has a peace full result---Steve out
My kids mother was in a terrible head on collision, broke everything on the left side of her body. Out of ICU and on the way to a rehab center for a long time, thanks for asking
A MGB Seat Cover Installation MG 1
B Seat Slide Installation Questions Austin Healey 14
J TR2/3/3A Seat kit padding installation Triumph 1
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
P TR6 tr6 seat cover installation Triumph 3
I 3 point seat belt installation help Spridgets 3
ronzet 3 point Seat Belts - Installation Austin Healey 4
L Front Seat Rails Installation Austin Healey 7
J Installation of seat slides. Austin Healey 15
davidk Seat Cover Installation Help Needed Triumph 7
M Seat Installation Spridgets 2
71tr TR6 TR6 seat upholstery installation Triumph 1
klutterbutt Seat cover installation MG 2
W TR2/3/3A TR3 Seat Belts Triumph 3
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
