Seat Cushions for a big behind!!!
pcanonge
Member
Just received some new seat cushions from OSJI.
Can anyone offer some insight before I take these tired seats apart? I know the seat bottom cushions come out with the removal of one screw. What I want to know is what to expect when I peal away the leather covers.
The leather is in great shape for its age and I intend to preserve it. How do I maintain the original shape? Hog rings??
Advice will be greatly appreciated.
P
in my '84, I had to first remove front frame bracket & screw located in front of the seat frame, and then seat motor switch and connections. After the seat is out of the car, then remove the rubber diaphragm from the bottom, then remove the down-pressure cords with washers, (I don't know what the upholsteric term is for those, but those are what shapes the leather to the foam shape), then carefully peel the leather cover off the foam shape, because time "glues" both of them together.
While you have the leather cover off, might be the time to install a Seat Heater, which I also did. Installation is the reverse of the above!
My 87 did not have hog rings. The leather was held with spring clips every few inches. Get a 90 degree scribe or awl to slip inder the spring clips to pry the clips off. A Sears Craftsman Cotter pin puller works well also. The leather is folded over the sheet metal channels of the seat frame and the clip holds it in place. A small ball peen hammer or an upholstery tack hammer works well to tap the spring clips in place.
I got the Driver side seat cushion replaced this weekend. What a difference!
I was a bit skeptical of the OSJI cushions. Once compared to the original (What was left) they seemed like they where incorrect.
After careful evaluation and a bit of glue the seat bottoms where as good as new.
My thanks to all who offered suggestions.
Later
P
B Revamped the BJ7 seat cushions Austin Healey 6
M Seat foam or cushions Spridgets 6
J seat cushions are not bad ? Austin Healey 3
J Installing Heritage Seat Kit - Bottom Cushions Austin Healey 6
lreyburn BJ8 Seat Cushions Austin Healey 5
19_again seat cushions MG 2
W TR2/3/3A TR3 Seat Belts Triumph 3
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
