General TR Seat belt dissassembly help
ichthos
I have a 69 TR6. I want to restore the original seat belts, (American Safety 6500, same as Spitfire belts). I have one buckle that needs to be taken apart as it has some surface rust and I will have to get it rechromed. I cannot figure out how to take it apart. The top of the buckle is held in place by a bolt which is split at the opposite end and a small metal wedge was pounded in to spread it and hold the bolt in place. Anyone tried to remove this pin, and if so can you give any tips to how this is done?
D TR2/3/3A layout for lap type seat belt Triumph 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
Michael Oritt Seat belt anchors--introduction Austin Healey 2
F TR6 Seat Belt Module? Triumph 4
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
T seat Belt Buzzer Wont shut off Triumph 5
C Stock seat belt color? Austin Healey 11
B seat belt upgrade complate ! MG 1
L 1978 mg midget seat belt replacement Spridgets 3
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
mdionne Seat Belt Problem Spridgets 3
mdionne Seat Belt Problem MG 2
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
S Need two of these seat belt brackets Austin Healey 3
I 3 point seat belt installation help Spridgets 3
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Gliderman8 Seat belt parkers anyone? Triumph 2
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
T Seat belt question.... MG 4
C Seat belt guide MG 0
J seat belt intallation in late BJ8 Austin Healey 24
Tinkerman TR2/3/3A Seat Belt Mounting TR 3A Triumph 6
tweety I need a Kangol seat belt Spridgets 1
T xj6 Seat Belt Jaguar 1
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
mrv8q TR6 TR6 Seat belt mounting question Triumph 3
dklawson Spitfire Spitfire - Seat Belt Anchor Bolts [Size?] Triumph 6
milemarker60 Miata Seat Belt Receiver Question Triumph 4
X Seat Belt Holders MG 5
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
A Seat Belt replace MG 3
A Break Warning Light & Seat Belt Extenders MG 3
A MG in NASCAR / Seat belt clips? MG 10
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
W Seat belt warning electricals MG 0
T Seat Belt screw Rover / Land Rover 3
Monark192 Seat Belt Mounting Bolts MG 0
