BT7 Seat Belt Mounting Acorn Nuts
Indnrdr
In my '62 BT7 I have those selt belt mounting studs with the acorn nuts (two each per rear fender well).
Of the seat belts adverstised, is there a set that mounts up as they historically did to these studs with the acorn nuts?
Which vendor(s) supply these?
Thanks.
D Rear Seat Side Panels, BT7 Austin Healey 3
R 3-point seat belts on late production BT7 MKII Austin Healey 7
D BT7 seat rails Austin Healey 8
7 Retractable seat belts - BT7 Austin Healey 8
Lin BT7 rear seat fasteners and install Austin Healey 7
Lin BT7 rear seat fasteners Austin Healey 0
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
