Scuttle shake finally sorted
bob hughes
Wooo hooo After much prevarication, hair pulling and anything else that you could think of I have finally got rid of the scuttle shake.
A new set of chrome wheels, hubs, spinners and Vredestein Classic Sprint tyres and there you have it - job done :encouragement:
And - as a bonus, there is no dreaded clunk as you apply the brakes as the new wheels are a great fit on the new hubs :triumphant:
That is the trouble when you do a rolling restoration - in what order do you tackle things - I picked the floor, suspension, soft top brakes and engine as priorities and I still have the boot floor to do - ( trunk).
:cheers:
Yes, thanks for posting. That will be my next challenge in the rolling restoration of my 100. I'll would also be interested to hear if you balanced the drums. Also, did you have the new tires and wheels balanced on or off the car?
Cheers!
Hi Guys
In short - no, the drums were not balanced.
When I bought the car back in 2002, through a Healey restorer acting as an agent, the price included ÂŁ500 to get it on the road! As far as I can remember, this included brand new rear drums, MOT and other things long forgotten. The wheels were the old 48 spokers and the tyres were very old then. Being of short in arm and long in pocket other things came first. It was long suspected that the tyres were the main problem, though I did research potential businesses who specialised in balancing things just in case I needed their expertise.
I bought the chrome wheels last year by chance when at a coffee morning at Bill Rawles' place, they were not new but very nearly new and at a price I could not ignore. The tyres came brand new via Ebay, direct from the Netherlands, again at a price I could not ignore and Bill fitted them onto the wheels using a static balancer. I must say, I was a bit sceptical but Bill assured me that he had no complaints. Discussing the scuttle shake with Charlie - Bill's son, whilst the tyres were being mounted, he suggested using the static balancer on the drums if the shake persisted after installing the wheels on the car, so I was prepared to give it a go, but as things turned out I did not need to.
The MOT was up last Thursday so I put the rear hub splines on as they were easy, put the new wheels on all round and added the spinners, strangely the new spinners would not fit the old splined front hubs so I had to refit the old ones and got the car to the MOT testing station where I am pleased to say that it passed with flying colours.
:cheers:
Bob,
What pressure are you running your tyres at? I have the same on my BN4 and run them at 30psi but not sure if this is correct. Thanks.
Mine are currently what has been put in at the shop some time ago it must be said - around 26, but when I bought the car I was told to shove in 30 all round, so I may top this up when I have finished installing the front hubs.
:cheers:
First time out today this year, glorious day could not be missed, recent winter work included having the rear springs re tempered, installing new Michelin XAS tyres, front wheel alignment and other general 'maintainance'. Took her up to a steady 70mph (sorry officer it was a dual carriageway!) and bingo noo scuttle shake zero zilch what a result. I am sure it's the tyres that made the difference as the rear drums were replaced last year with no effect. Did notice the front end was a little 'lighter' on steering could this be because the rear end was a little higher? Or due to going a little strong on the toe in.
(sorry officer it was a dual carriageway!)in.
For those of you on this side of the pond as an ex Brit I will translate .
Dual Carriageway = divided highway or interstate . Usually two lanes each way .
While doing some research on the Rolls-Healey I learned that one of the improvements made to the 3000 chassis was replacing the fiberglass transmission tunnel with a solid steel tunnel to combat scuttle shake. Obviously a bit extreme for our cars, but I think it points out that a certain degree of scuttle shake was inherent in the design, particularly on the convertibles that carried the extra weight of the larger windshield. Tracking down the source of scuttle shake is made more difficult by the fact that it can be due to various sources and which is why owners can spend a bunch hunting it down. Worn front suspension, out of balance wheels, out of round tires, out of balance rear brake drums are all suspects. I finally beat it with new wheels and tires, shaved for roundness along with balanced rear drums, all done by Hendrix Wire Wheels and doing the scuttle shake mod while my motor was out: https://www.britishcarweek.org/scuttle.html. The car track true and with my V8 and 5 speed turning 2200 rpm at 70 mph, it's a true joy on highway runs. My point is not to pat myself on the back, but to let people know that although the chase to find the cause of the shake can be a long one, the end result is really worth it and the car is transformed after that annoying shake is gone right at the driving sweet spot.
That sweet spot on our Welsh roads is normally 45 to 60 mph and she used to shake a little about mid that point could drive out of it but that was too quick. Will do the tunnel modification when the power plant comes out but hey what a joy to drive now with the new correctly balanced tyres thanks to longstone tyres.
Hi All,
It is amazing how often over the years I had the wheels and tires balanced but never thought of balancing the drums. I had always thought the drums were balanced at the factory when manufactured as was the practice of American cars at the time and never thought this was not the case for my Healey...especially since the drums are so large and heavy. A while back, when statically balancing my drums, I found in excess of 5 or more ounces out of balance which is quite a bit.
As I see it, the underlying issue is a design fault in the Healey substructure that seems to amplify and transmit rear wheel (wheels, tires, drums, etc.) balancing imperfections and aggravatingly appears between the commonly driven speeds of 45 and 60 mph. To add to the issue is the fact that the amplitude of this imbalance is not consistent and seems to be determined by the relationship of left and right wheel imbalances as varied by the differential. Although I have no specific clue where to modify the underlying design to eliminate the potential of scuttle shake, it is apparent that many have had success when truing and balancing wheels, tires, and drums. Since these balancing elements also vary, it is not that unheard of to find some drums to be close enough to balance not to be a contributing cause of scuttle shake. However, finding servicers that have the expertise, understanding, and equipment to address these balancing issues are quickly disappearing.
Just my thoughts,
Ray(64BJ8P1)
My dad was a factory rep for Ford when the Mustang came out. He said the Mustang convertibles had similar vibration issues, and that Ford never fully resolved them, though some extra bracing in the undercarriage helped. 'Shake' is pretty much endemic to droptops; even though they usually weigh a few hundred pounds more than hardtop versions due to additional chassis reinforcement. I have no data, but suspect the effect is exacerbated by most cars being monocoque--aka 'unibody'--design (presumably, with body-on-frame the shake could be damped with shock-absorbing mounts).
I'd like to hear from owners who have managed to eliminate scuttle shake though careful balancing of rotating parts how long the 'fix' works since tires, at least, are subject to uneven wear no matter how often they're rotated.
My tricarbs' shuttle shake it caused by potholes and RR crossings. Not driveline vibration.
Where can I learn more about reinforcement of the transmission opening in the firewall?
Thanks.
Douglas
steveg Steering column steady brace and scuttle shake? Austin Healey 2
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
PAUL161 T-Series Scuttle Shake/Vibration MG 6
S Scuttle Shake Austin Healey 95
5 The scuttle shake mod- I can't decide Austin Healey 7
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
richberman Scuttle Shake solutions, necessary? Austin Healey 24
J What is scuttle shake and is there a cure? Austin Healey 9
Randy Harris Scuttle shake at 55 Austin Healey 20
C Rattletrap [ Scuttle Shake ] Austin Healey 46
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
H clear coat question on scuttle Austin Healey 7
PatGalvin Scuttle Vent Rubber placement Triumph 4
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M Sebring Scuttle Vent Austin Healey 3
H Scuttle Seals Austin Healey 2
curtis BN2 scuttle seal Austin Healey 13
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
ekamm scuttle knob Triumph 6
M TR2/3/3A Tr3 scuttle mechanism Triumph 2
S TR6 76 TR6 Scuttle Vent Triumph 16
O TR2/3/3A TR3 Scuttle Panel Still Needed! Triumph 5
O TR2/3/3A TR3 Scuttle Panel Triumph 8
G Scuttle Vent Adjustment Triumph 1
