Scuttle Vent Adjustment
G
Well, thanks to all of your suggestions, and pure dumb luck, I am down to the last item on my "First 30 Days To Do List." I installed my hood stick cover this morning, after remembering an old friend upholstery shop a few miles away who worked on my Miata tonneau cover a few years ago. He let me go over to his shop and use his lift-the-dot tool (punch). The holes took all of 10 minutes and the hardware about 20 minutes. Life is sure easy when you have the right tool.
I am told that the vent lid can only be adjusted thru the lid, and that it is a nightmare. (My lid opens about two inches, then falls closed as soon as the know is released.) Most people say to leave it alone, as all it does is bring hot air into the cabin, along with a grasshopper now and then.
Good points. However, being the neat-freak that I am, I would like it to work properly IF IT IS WITHIN THE REALM OF MY EXPERTISE (the original Gordon Badwrench). Back to the lid, I see a small hexagonal screw that looks like the pull wire runs to. Is this correct?
If this is correct, do I have to loosen that screw to adjust the length of the pull wire? If that is the case, I may be finished before I start, as I don't know if I have a socket that small. I have the necessary extensions and elbows for the socket, if I have the socket. But, first, I want to hear from someone who has DONE this project, and heed his/her words of wisdom.
You have come thru in the past, so I expect nothing less this time also. You have spoiled me rotten!! In a VERY short time!
My sister visits from Baltimore next week, and I am looking forward to taking her for a ride in my new TR.
Peace,
TR3driver
Great Pumpkin - R.I.P
Yes, there is a small hex screw that pinches the pull rod. You loosen that to adjust the length of the rod. I used a small open-end wrench to turn mine, think it was 1/4" but I'm not certain offhand.
However, I suspect that is not your problem. The knob pulls out to open the vent; so having the rod adjusted too short would mean the lid would not close all the way, and having it too long would just mean the knob comes out farther. You must have something else interfering with the lid coming open, like the linkage assembled wrong.
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
C TR2/3/3A scuttle vent Triumph 6
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
PatGalvin Scuttle Vent Rubber placement Triumph 4
M Sebring Scuttle Vent Austin Healey 3
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
S TR6 76 TR6 Scuttle Vent Triumph 16
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
71tr Scuttle Vent Removal Triumph 7
P TR2/3/3A TR-3a scuttle vent assembly question Triumph 2
B TR2/3/3A TR-3 SCUTTLE VENT ROD INSTALLATION? Triumph 14
T TR4/4A 4A Scuttle Vent Seal-Gasket Triumph 6
NutmegCT TR2/3/3A scuttle vent actuator rod - TR3A Triumph 3
R TR6 TR6 scuttle vent style Triumph 12
G Scuttle vent conversion Triumph 1
harmsc Scuttle Vent Triumph 6
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
