TR6 Scuttle lid spring?
ckdove
I'm converting my vent screen to the scuttle lid and can't figure out how the spring sits/attaches to the firewall. Looking for a picture of an earlier model showing how the spring rests in position. Thanks.
It's a bit of an awkward shot but here you go. The spring is oriented forward into two spot welded clips on the bulkhead that are roughly above the two screws that hold the clips for routing the bonnet release cable. This shot is taken from the right hand side of the car showing that clip. Without the light in the picture, the spring and clips would not show up in the photo. I could not get the light balanced to be able to show both clips, but this should be enough to give you the general layout.
Thank you Tybalt! That is perfect. Since my car was built with the screen cover the welded clips are not there so I will need to get creative. Your picture answers my question spot on.
Since you don't have the clips, perhaps something like these:
https://www.aircraftspruce.com/catalog/appages/ms21919clamps.php?clickkey=94160
or these:
https://www.mcmaster.com/#hose-clamps/=1b99vz6 (select the routing clamps, then when on that page, scroll down to loop clamps if the McMaster page only gets you part of the way there)
could be used for making the hinge line for the spring. As far as the depth of that hinge line in that well, there is a lip at the opening that a channel in the seal fits over. From the top of that lip down to the hinge line for the spring, you looking at something between 1'' and 1 1/8".
I was thinking the same and the measurement for the spring line helps. I'll post pics when done. Thanks
Success! Works perfect. I attached two small rubberized c clamps (ace hardware) to the inside of the scuttle to hold the spring. You can see the outside location where the two shiny bolts are just below the bonnet seal. The two attachment points for the later model black screen are still in place if some day it needs to be changed back.
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
PatGalvin Scuttle Vent Rubber placement Triumph 4
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M Sebring Scuttle Vent Austin Healey 3
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
curtis BN2 scuttle seal Austin Healey 13
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
richberman Scuttle Shake solutions, necessary? Austin Healey 24
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
ekamm scuttle knob Triumph 6
M TR2/3/3A Tr3 scuttle mechanism Triumph 2
S TR6 76 TR6 Scuttle Vent Triumph 16
O TR2/3/3A TR3 Scuttle Panel Still Needed! Triumph 5
O TR2/3/3A TR3 Scuttle Panel Triumph 8
G Scuttle Vent Adjustment Triumph 1
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
mjobrien Chassis to Scuttle - Gasket - Filler - Foam? Austin Healey 13
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
