    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Rocker Pedestal Shims
baynes
The .005" shims not fitted to the two middle rocker pedestals,on MGB to prevent fretting, intend to make some.
Do not know material used for origionals ? I intend to use brass, any comments on this or steel.
Mickey Richaud Rocker Pedestal Shims MG 14
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
CJD TR2/3/3A Rocker Pedestal Triumph 9
M Rocker pedestal stuck...! Austin Healey 7
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
texas_bugeye Rocker pedestal Height Spridgets 9
G Torquing rocker pedestal changed clearances Triumph 1
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
Lin threaded rocker pedestal Austin Healey 5
kch Rocker pedestal - oil feed threads ? Austin Healey 13
R Rocker Pedestal Problem Austin Healey 2
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
