Rocker cover rivets
Lin
When installing the rivets to secure the two plates on top of the rocker cover do you just place the top of the cover (head of rivet) against something hard and then hit the hollow rivet shaft with a ball peen hammer on the inside of the rocker cover? No reason to heat one of these little hollow rivets is there?
Any tips?
Lin
1960 BT7 in restoration
1959 Bugeye
ThomP
My experince is that using a hammer is the risky way to go. I put the stuff in a small arbor press and crush it with the press. The process is way more controlled and less likley to dent the wrong thing. No heat required.
Cutlass
If you have a local Experimental Aircraft Association (EAA) chapter nearby, one of their members will be more than happy to squeeze those suckers on properly for you.
Hamish Racing General TR Rocker cover identification please. Triumph 2
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
P Rocker Cover Vent Spridgets 22
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
stretchit2 Rocker Cover Austin Healey 12
M Moisture in Rocker cover Spridgets 5
P Valve/Rocker cover Austin Healey 5
T Minifin Rocker Cover Spridgets 3
64rocksprite rocker cover vs 1.5 rockers..fit? Spridgets 3
M T-Series Is a plugged TD rocker cover vent tube OK? MG 11
BritCarFan Rocker cover gasket help MG 19
A Rocker Cover Gasket... Spridgets 33
weewillie valve / rocker cover Spridgets 7
wingsandwheels TR6 Alloy rocker cover, late TR6 Triumph 2
A Rocker Cover Paint Spridgets 9
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
