Ring gear replacement
lbcfan
I have an amusing "shade-tree mechanic" question.
I want to change the ring gear on my rebuilt 1275- old one is slightly chewed... with no torch I was wondering if I can freeze the flywheel and heat the ring in my gas grill (about 6-700 degrees) to get the ring to slip on. I've heard of it it being done for small engines.
I would remove the old ring by sawing partially through and then using a cold chisel.
While I'm at it, the flywheel, which I've unbolted, resists removal. I'm afraid to force it by prying. Is there a trick to it, or do I need a puller?
Thanks for any advice.
Michael
smaceng
Check the search function as there was a recent lengthy discussion on this subject with many great ideas.
Scott in CA
Gerard
Michael
Michael,
The 1275, unlike the 948 and 1098, have two press fit locating pins and a recess in the flywheel that is a tight fit on the crank flange. You should not need a puller, but will take a little persuasion via judicious prying to come off. Keep a hold on it, lots of near horizontal surface underneath and toes clear... :hammer:
If heard the technique you suggest for the ring gear before and seems to be a working solution. Never done it myself though.
G
Pry a little bit on alrenating sides. It'll come off. The JB Racing ultra lite flywheels we had on the race cars had a taper fit that was pretty tight. You could loosly thread a bolt part way in to keeop it from dropping on your toes, just be carefull not to cock the wheel too much and bind the bolt.
I tried my over @ 500 degrees but it didn't work. I had to throw it on the BBQ pit.
TulsaFred
I used a cutting wheel to cut almost through the ring gear, then struck it with a cold chisel and it came right off easily.
I then used my gas grill on high (about 600+ degrees) and put the new ring gear on the grill for about 15 minutes.
It dropped right down on the flywheel with no problem. Tightened right up when cool.
Easy.
Fred
L
lbcfan
Thanks to all for the replies. I got the flywheel off using the recommended techniques, along with a heavy hammer through the starter hole.
If the grill works to heat the ring I'll Email Weber- it may be a selling point...
nomad
I've used the chisel to cut the old ring gear and heat to apply the new several times. Used to do a lot of motorcyle work. Bearings in the freezer and cases in the oven. Bearing replacement was always drop in!
Kurt.
D Flywheel Ring-gear replacement Spridgets 18
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
DrEntropy MGB Ring Gear Roulette MG 12
J TR6 Ring gear repair Triumph 13
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
R Installing pinion and ring gear Austin Healey 11
S TR2/3/3A Removing the shrunk on ring gear Triumph 4
T MGB MGB 1800 ring gear MG 2
MikeAH100M Pinion/Ring Gear Lash Spridgets 2
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
B 2nd gear blocking ring failure BJ7 Austin Healey 5
SilentUnicorn Ring Gear-question on condition MG 7
I Correct ring and pinion gear ratio for Bugeye? Spridgets 5
Hap Waldrop Replacing a flywheel ring gear Spridgets 13
G Trouble getting flywheel ring gear on. Spridgets 23
germanmichel Fly wheel -gear ring and clutch disc questions Austin Healey 13
prb51 TR2/3/3A TR3 Ring gear Triumph 8
MTribe gear reduction starter fix ring gear bevel? Triumph 5
M Criteria for replacing Flywheel Ring Gear Triumph 1
Tinkerman Post 60000 TR 3 Ring Gear Bolt Torque? Triumph 1
Baz Ring gear wear.... Spridgets 4
Tinkerman TR 3 Ring gear to flywheel orientation? Triumph 3
B Anyone fitted a flywheel ring gear? MG 14
M XJ6 flwheel ring gear smaller than flex plate ring Jaguar 5
NutmegCT ring gear teeth Triumph 6
healeyboz ring gear Spridgets 23
G New Ring Gear or the Big Kahuna........Aluminum Triumph 5
Tinkerman TR2/3/3A TR-3A Ring Gear Bolts Triumph 3
R6MGS Flywheel/Ring gear....Refinishing MG 1
zimmy HOW TO change a ring gear with pics ; ] Spridgets 5
M TR6 74 TR6 flywheel ring gear Triumph 1
G Ring Gear in the Oven-Fly Wheel in the Freezer Triumph 12
Dave Richards 3.54 ring and pinion gear Austin Healey 13
J starter and ring gear Triumph 14
71tr Ring Gear Triumph 13
sail TR4/4A Piston Ring Question Triumph 6
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
T How do I clean sand out of a ring & pinion? Spridgets 2
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
