TR6 Reveneering TR6 Dash
ichthos
Hello All,
I am in the process of reveneering my dash. The old veneer was shot on my original dash, so I had no choice but to remove it. I also had to make some repairs to the core itself. My Dad has had some rosewood veneer lying around for at least the last 35 years; I decided to face my dash with it. I am a decent wood worker, but I have not done much veneer work. I have already glued the rosewood veneer in place with waterproof glue. Does someone have any recommendations on how to cut out the holes? The rosewood is kind of brittle, and I am nervous about chipping or splitting it. Any suggestions would greatly be appreciated.
Kevin
Kevin
Take your time and replace the X-Acto blade if the veneer starts to crack and not cut. I used a spray bottle with some water and sprayed the veneer with some water on the brittle redwood burl dash I made for my Dad's 48 TR. It helped soften the wood and made cutting easier. Since your cutting out that area you don't have to worry about staining the wood and any wicking didn't water stain the wood enough to be a problem. After getting the area wet, remove the bulk of the material and then concentrate on your edges.
Paul
I found the best way to cut out the holes is to place the dash veneer side down on a flat surface like a sheet of particle board or plywood. Use a sharp Xacto knife or a routing bit in a Dremel to cut out the holes to within 1/4" of the edge of the hole. Flip the dash over and chuck a sanding drum in the Dremel to remove the remaining 1/4". Make sure you keep the Dremel vertical or, even better yet, use one of the routing guides that attach to the nose of the Dremel. The sanding drum will cut through the veneer pretty easily and it will be quite noticable when you hit the side of the hole. Go slow and be patient and you shouldn't get any tearout.
Kevin,try a little sanding sealer if your going the water method. It will help keep the absorption down
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
tr6nitjulius TR6 TR6 N IT That SOUND FEEL LOOK! Triumph 0
K For Sale 1974 TR6 For Sale Triumph Classifieds 0
B For Sale TR6 parts for sale Triumph Classifieds 0
T TR6 TR6 blower motor and fuel gauge won't work Triumph 10
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
Number_6 TR6 Paul’s TR6 Triumph 9
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 5
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
