    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 rear brakes
rjc157
In the process of installing new rear brake shoes on my 75 tr6 do I have to cut the drums to get them on these are from Moss the thing is is that the drum just doesn't fit over them any help is appreciated
To help clarify - are the brakes fully released? (parking brake released, shoes completely retracted)
If the old shoe linings were well worn and thin, the shoes may have been adjusted fully outward (expanded) - so they'll need to be fully retracted to accept the old drum.
- did the drum slide off the old shoes easily?
Assuming Moss sent the correct shoes - do the new shoes fit snugly into the drum? Shoe face flush against the inside of the drum?
Tom M.
Just picked up this car it's a 75 going through everything po was not a tr6 guy so I don't know what he did or didn't do it was alittle difficult getting the drums off linings were down to almost nothing doubt they were ever changed thought the cylinder was frozen took it out and cleaned it might have a bad hose gonna try again to flush out the system not that easy for a one man job not sure totally what you mean by shoes fitting snugly I can't get the drum on at all
What you describe leads me to believe those adjusters aren't fully retracted (not fully "backed off").
You've cleaned the entire mechanism with brake cleaner, etc.?
The new friction linings are sometimes too thick to install easily. It used to be that the parts store would grind them to match the drums, but I don't think anyone does that any more.
So, be sure the adjusters are backed off, and tap the wheel cylinder around to get the shoes centered. Then if it still won't fit, file down the shoes until they do fit.
Make sure the parking brake is not only released at the handle, but releasing at the brake, maybe the cable is stuck.
It is the adjusters one I was able to back all the way out and hub went on the other one is frozen stuck can't get it to turn any suggestions
Heat will help, use a propane torch to get the adjuster body as hot as you can then try turning the screw while it is still hot. Once it starts to move, keep working it back and forth until it comes apart. Be sure to use either a square wrench or 8 point socket to turn it. Other things (like the obvious open end wrench) are more likely to round/ruin the screw.
Once it moves obviously you'll disassemble for cleaning and chasing the threads. A thin coat of copper-based anti-seize will help keep it free for easy future adjustment.
If all else fails, new adjusters are available.
KVH General Tech Rear Brakes and Solid Axle Triumph 2
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
R TR2/3/3A Rear Brakes Triumph 9
M TR6 Rear brakes Triumph 2
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Rear brakes - spring plates and drum alignment Triumph 3
oxford Rear Brakes [again!!] Austin Healey 17
oxford rear brakes Austin Healey 14
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
Jim_Gruber Upgrading rear brakes on a BE Spridgets 6
J TR2/3/3A Installation of rear brake cylinders for 9" brakes on TR 3A. Triumph 3
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
J TR2/3/3A Rear brakes are not locking up hard enough. Triumph 11
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
Boggsy64 MGB Rear brakes caution MG 1
T TR2/3/3A TR 3a. Rear brakes Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
S TR2/3/3A rear brakes tr3 Triumph 1
M Bugeye rear brakes Spridgets 3
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
M squeaky rear brakes Spridgets 4
W TR6 broken bleeder on rear brakes tr6 Triumph 12
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
TraceZ How I adjusted my new rear brakes Spridgets 7
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
S Spitfire spitfire rear brakes Triumph 5
S installation of rear brakes Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
Moseso TR2/3/3A TR3 Rear Brakes -- A Bold Experiment Triumph 22
P REAR DRUM BRAKES Spridgets 1
M Rear Brakes [from hi-jacked thread] Spridgets 6
M rear disk brakes Spridgets 0
W JagMKII rear brakes dragging Jaguar 13
TimK sticking rear brakes Austin Healey 8
C T-Series Need help to free up rear brakes on TD MG 8
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
D Rear brakes soaked with grease Austin Healey 2
R Rear Drum Brakes on a BE Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
D Wedge Rear Disc Brakes for TR7 Triumph 16
drooartz Tunebuggery Day 3 -- rear brakes done[ish]! Spridgets 12
